Is This Proper Ventilation? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-15-2009, 06:13 PM   #1
Is this proper ventilation?
I have gable roof with a 90’ foot ridge. I plan on using a Ridge vent (Cobra Snow Country) to help ventilate my attic. According to 1/300 rule (2700 sq. ft. of attic), I calculated that I need 648 Sq. inches of NFVA exhaust ventilation and 648 sq. inches of NFVA intake. The ridge vent I plan on using has specs of 16 sq. inches per lineal foot NFVA that comes out to (16x90ft) 1440 sq. inches of NFVA. Is this too much or can I balance this out with more under eave vents? I have the feeling that my 1960’s home doesn’t have the proper amount ventilation passing through the eaves. What should I do? Does anybody have a better recommendation for ridge vent other than Cobra? Are my NFVA calculations correct?
DIY2009 is offline   Reply With Quote
Old 08-15-2009, 07:54 PM   #2
Shingle Vent II from has 18 square inches per foot.
But, you really need to address the amount of Intake Ventilation to make any type of Exhaust Venting work properly.
Ed the Roofer is offline   Reply With Quote
attic ventilation lou1968 Roofing/Siding 5 05-31-2009 09:33 PM
Ice dam and soffet ventilation jvanostrand Roofing/Siding 3 02-11-2009 03:44 PM
Proper Attic Ventilation kmhill35 Roofing/Siding 2 04-01-2005 08:11 PM
What is the proper ventilation needed? Ice Damns causing problems. alanisaacson Roofing/Siding 1 01-07-2005 01:38 PM
