Proper Solar Panel Installation - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-23-2012, 05:47 PM   #1
Rewards Points: 590
Proper solar panel installation
I'm planning on installing three 15W solar panels on my 3 year old shingle roof, and I want to make sure I don't have any leaks. These will just be mounted on metal brackets with at least 1" of space below them for ventilation, no fancy tilt mechanism (my roof is 8-12 pitch, which is a pretty good angle for optimum output in the winter). How should I do this? I watched a video from a DIY solar vendor who seemed to just use silicone caulk (I assume; it was white) around the drilled holes before placing the bracket on top and screwing it in. And how do I handle the power cables?
operagost is offline   Reply With Quote
Old 03-24-2012, 10:53 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 906
PVC electrical conduit in conjunction with a proper roof boot.
The Following User Says Thank You to Windows on Wash For This Useful Post:
operagost (03-25-2012)
Old 03-24-2012, 11:16 AM   #3
Rewards Points: 2,238
What "Windows on Wash" says!
However, don't use "Silicone"!
Use "Quad" - "Solar Seal" - "Vulkem".....
"RF"
rossfingal is offline   Reply With Quote
The Following User Says Thank You to rossfingal For This Useful Post:
Old 03-24-2012, 11:52 AM   #4
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 46
I've been pondering this myself as I'd like to maybe go solar. Though the biggest thing is figuring out some kind of mechanism that keeps the snow off, and that mechanism has to use less power than what the solar panels produce, or it's kinda pointless.
For the mounting I was thinking some kind of T brackets that slide under the shingles and are nailed from under. You don't want to just nail/screw anything directly on the shingles. Exposed nail heads = potential leak. Even with proper sealing product, I would just not trust that many exposed nail heads. I wonder how the professional installers do it. Maybe I'm just being overcautious for nothing in my thinking.
Old 03-24-2012, 01:39 PM   #5
I don't see anything wrong with being "overcautious"!
"RF"
Old 03-25-2012, 12:30 AM   #6
Rewards Points: 590
My pitch is enough to allow a light snow to easily slide off (remember, the panels are relatively smooth and dark in color) and since that section of the house is only one story, I plan to use the broom-and-ladder technology to remove anything heavy (the other section of the roof is much shallower in pitch, so I shouldn't be causing an avalanche).
Old 03-25-2012, 12:31 AM   #7
Rewards Points: 590
I've seen some one-piece cast aluminum posts for this, but I haven't found a consumer supplier. I don't need 50, ya know?
Old 03-25-2012, 09:16 AM   #8
Metal Roofing
Rewards Points: 600
A fastjack with a roof flashing like the link below, thats how i would do it.
http://www.prosolar.com/prosolar-new...s-subpage2.htm
Select the fastjact pdf, it show the standoff base, the stand off and i think if you scroll down it shows the installtion in a comp roof.
AndyWRS is offline   Reply With Quote
The Following User Says Thank You to AndyWRS For This Useful Post:
operagost (03-27-2012)
Old 03-27-2012, 12:47 PM   #9
Rewards Points: 590
That's what I was thinking of. But why is it that every job requires that I buy a new tool (the impact driver)!
Old 03-27-2012, 03:59 PM   #10
Wire Chewer
Rewards Points: 46
I know the feeling.
I rented a jackhammer twice last year for one job and it's still not done. I should of bought the damn thing. LOL
Old 03-27-2012, 07:45 PM   #11
Metal Roofing
Rewards Points: 600
I use mine so often i couldnt live without one. For me, its my most used tool at work / home. I probably use it everyday.
Old House Rewire finnimus Electrical 15 05-13-2011 11:39 PM
Grid Tie Solar Panel Manual Transfer Switch Possible? tomguy Electrical 5 04-08-2011 04:55 PM
Sub Panel Installation ironnickwhite Electrical 10 03-30-2011 10:18 PM
Aluminum solar panel frame ideas wanted easytim Building & Construction 5 08-03-2008 03:40 PM
Multiple Sub Panel Installation Handyman2007 Electrical 26 12-31-2007 06:47 PM
