Proper Roofing Technique - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-14-2011, 01:18 PM   #1
proper roofing technique
Would you help me in properly evaluating my new roof...it does not look good.Thank you so much and I promise the kids next door didn't install this.
proper roofing technique-dsc_9179.jpg   proper roofing technique-dsc_9190.jpg   proper roofing technique-dsc_9198.jpg   proper roofing technique-dsc_9204.jpg   proper roofing technique-dsc_9203.jpg
blazer7 is offline   Reply With Quote
Old 06-14-2011, 05:07 PM   #2
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
The flashing looks like it was chewed by a beaver at the bottoms, but is installed correctly. The flags should be pop riveted together, IMHO, which would make them hug the wall.
Most of the rest of the stuff is a little sloppy, but will probably lay down after a few days of direct sun. I'd just about have to be on the roof to make a call on some of those items. Look at them in a week and see if some of the unevenness has gone away.
seeyou is offline   Reply With Quote
Old 06-14-2011, 05:20 PM   #3
Gymschu's Avatar
Rewards Points: 208
Who did the flashing? Mrs. Staments pre-school class?
Proper Roofing Techniques? JoWarren Roofing/Siding 5 03-26-2011 04:26 PM
Proper technique? veesubotee HVAC 5 05-01-2010 06:36 PM
need advice of choosing the proper roofing shingle product nc_yella Roofing/Siding 10 11-19-2008 04:49 PM
Proper inside framing/insulation/vapor barrier technique trevorjwilson Building & Construction 1 11-20-2007 06:21 AM
