Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing/Siding
Old 09-15-2012, 07:36 PM   #16
Doing This Way Too Long
Proper roofing of low sloped roof
Originally Posted by daluu View Post
both proposed 2 layers of (30 lb) felt paper for the underlayment to properly protect from leaks
Whatever you choose to do do NOT hire anyone who told you this. No roofer worth his salt depends on the underlayment to stop leaks. You are in Northern Cali, not south Florida.
We have successfully converted many roofs exactly like yours to shingles around here and the underlayment had nothing to do with how well the roof performed. As others have said, a single-ply is always a good options also.
OldNBroken is offline   Reply With Quote
Old 09-15-2012, 11:13 PM   #17
Never understood the tar paper for leaks thing, with all those holes it is going to leak
mae-ling is offline   Reply With Quote
Old 09-15-2012, 11:20 PM   #18
Thanks for the advice OldNBroken. The roofers didn't specifically say it like that (my bad paraphrasing) but that (1) that is required for the roof materials to be warranty covered by the materials manufacturer (else it would be considered improper installation of shingle roof for the given pitch), and (2) that it would provide better protection against water intrusion. At least those 2 roofers were better than one that came by and said the roof is still good for a few years without mentioning any issues (or guess he too busy to want my business otherwise).
Just curious then, for roof of my pitch, what would one expect a knowledgeable roofer say to me? I was unsure at the time (still am) so when asked what type of roof to replace with, I said shingle since that's what it currently is. So I would assume there response would be in regards to a shingle roof, unless they highly suggest I go with an alternative roof type like the single ply.
daluu is offline   Reply With Quote
Old 09-16-2012, 02:25 AM   #19
GBrackins's Avatar
daluu,
this information is from the 2009 International Residential Code, which is the basis for the California Residential Code (http://publicecodes.cyberregs.com/st/ca/st/index.htm).
R905.2.2 Slope. Asphalt shingles shall be used only on roof slopes of two units vertical in 12 units horizontal (2:12) or greater. For roof slopes from two units vertical in 12 units horizontal (2:12) up to four units vertical in 12 units horizontal (4:12), double underlayment application is required in accordance with Section R905.2.7.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
rubber roof over tar & thoughts on quote wfmrules3 Roofing/Siding 13 10-16-2011 10:00 PM
EPDM - flat roof to sloped roof transition emtaboy Roofing/Siding 12 07-14-2010 01:12 AM
1/12 sloped roof leaking w/ asphalt shingles, replacement ideas? Tuffguy610 Roofing/Siding 3 03-17-2010 06:59 AM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 07:17 AM
What roofing material is right for me? Grumpy Roofing/Siding 0 07-07-2004 08:41 PM
