Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 04-02-2010, 11:02 AM   #1
Proper Roof Ventilation
I have a three story house with a metal roof, 10/12 pitch. There are 2x4 joists and the owner packed them full of insulation and drywalled over them. There is no ventilation so obviously the drywall seams crack all over. What is the right way to vent a roof on a house like this? Do I need a vent on the outside to the exterior or a vent on the inside to the interior? I would like to have a finished third floor but the seams keep cracking.
Thanks.
jonathan03 is offline   Reply With Quote
Old 04-02-2010, 11:48 AM   #2
Solutions (handyman)
Venting a roof is important because it lets the warm air from the inside escape rather that accumulate at the highest points. There should be vents (Soffits) under the eaves on the outside and and vents high up on the roof. This allows for proper circulation. Chec out a ridge vent on the net to see an option worth considering. The ridge vent may be the easiest solution to your issue. Also, there should be a space between the insulation and the roof sheathing to allow for air movement. If the insulation is over sized, blocking the flow of air, the problem may (probably will) continue.
Good luck.
Mark Harvey is offline   Reply With Quote
Old 04-02-2010, 11:55 AM   #3
I should have added that my house is 130 years old, balloon frame construction with a 10/12 pitched metal roof. It has box gutters which I need to redo anyway. The third floor is a half story and I want to keep it finished.
Should I add vents in the bottom of the box gutters like soffits in new construction? Or is it a waste of time because something else will block the flow of air?
Old 04-02-2010, 08:33 PM   #4
With a building of that vintage, I'd contact a local roofing company or history buff to see more about the actual construction. The principal is the same in that you should have proper ventilation but I'm not sure what can or can't be done without disrupting the integrety of the building. Again, ask around. If you know of other buildings of a similar nature, especially in your neck of the woods, ... if you feel comfortable... knock on the door and ask the questions. Others may have gone through this before and you won't have to re-invent the wheel. Hope this helps.
Old 04-03-2010, 12:44 AM   #5
Commercial Roofing
AaronB's Avatar
Your ceilings are probably cracking from the weight of the drywall and/or snow load.
Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
need some advice on best roof ventilation for this house longshanks Roofing 9 07-26-2009 07:49 AM
1953 cape cod roof ventilation eraceme2 Roofing 7 04-27-2009 11:23 AM
Flat roof questions, advice, ballpark estimate JerryH Roofing 18 11-07-2008 05:08 PM
added metal roof advice on ventilation citadelcadet Roofing 5 08-20-2008 01:11 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing 4 11-19-2006 07:17 AM
