Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 04-25-2012, 01:58 PM   #1
proper flashing where shingles meet brick
I am having a new home built and and the shingles and brick were installed before flashing was placed where the two meet. The builders remedy was to slide flashing under the shingles but over the brick with exposed flashing over the brick and simply sealed with caulking. many similar homes in same area (same builder) has flashing placed before shingles and brick which seems to me to be more appropriate and certainly better aesthetically. please advise .
tom goodman is offline   Reply With Quote
Old 04-26-2012, 08:05 AM   #2
Pro Slate Roofer
tinner666's Avatar
The flashing need to be seperate from the counter-flashing. It's always a two-part system. Pictures would be helpful.
Frank
tinner666 is offline   Reply With Quote
Old 04-26-2012, 08:19 AM   #3
As Tinner said, you need flashing AND counter flashing.
The flashing is as your builder suggested, a 90 degree bent step flash that goes over/under each shingle and against the side of the chimney.
The counter flashing is embeded into the chimney just above the other flashing, extending downward to about an inch off the roofing, essentially hiding the step flashing.
bcdemon is offline   Reply With Quote
Old 04-26-2012, 01:04 PM   #4
http://www.jackdeveronline.com/how_t...ng_chimney.pdf
Brick veneer is 4 rows below grade- redo or leave? cbrc5eric Building & Construction 11 12-27-2011 09:09 PM
Re-roofing Architectural Shingles over Architectural Shingles NoDIY4Me Roofing 9 09-04-2011 10:29 AM
Proper Way to Attach Travertine to Brick... 99altrade Building & Construction 16 12-08-2010 08:56 PM
Do architectural shingles really work with step flashing? Malcolm Roofing 7 05-02-2008 11:31 PM
Flashing against brick? sandyman720 Roofing 6 03-22-2007 09:36 PM
