Proper Chimney Flashing - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-25-2010, 02:42 PM   #1
Proper chimney flashing
Is it ever correct to place copper chimney flashing over the shingles? I have two chimneys that had this done. One chimney is a full in plane chimney and another a partial in plane chimney. I am not sure what was done under the copper flashing. Also, I read an earlier post about making sure not to use gutter caulking around the pieces which is what it looks like to me has been done to my copper flashing. Why is this not a good idea?
Thanks.
Ron
tg028 is offline   Reply With Quote
Old 07-25-2010, 03:51 PM   #2
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
Thanks.
Ron
On the low side the apron should extend over the shingles. Elsewhere the base/step flashing should be interlaced with the shingles - one step flashing for each course of shingles. Gutter caulk is for gutters. One reason for using copper is that it can be soldered if necessary. Got any pics?
seeyou is offline   Reply With Quote
Old 07-25-2010, 04:02 PM   #3
Registered User
Rewards Points: 5,466
http://www.rumford.com/chimneys/flashing.html
http://www.rd.com/17758/article17758.html
Be safe, Gary
Old 07-25-2010, 04:35 PM   #4
Here are two pictures.
The Following User Says Thank You to tg028 For This Useful Post:
seeyou (07-25-2010)
Old 07-25-2010, 04:51 PM   #5
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
That's a mess. Whoever did that needs a remedial flashing course.
Old 07-25-2010, 04:55 PM   #6
So I take it as an improper flashing install?! What would you say are my remedies as a customer who had this done?
Old 07-25-2010, 05:14 PM   #7
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
Have you already paid? If not, don't.
Does it leak? It might be watertight, but it's pretty ugly. It looks like they may have left the old flashing in place and installed the new over the top of it.
Only remedy I know is to get someone who knows how to flash to do it properly. You ought to be able to tell if they know what they're doing by the expression on their face when they see that.
The Following 2 Users Say Thank You to seeyou For This Useful Post:
tg028 (07-25-2010), Tom Struble (07-25-2010)
Old 07-25-2010, 07:13 PM   #8
Tom Struble's Avatar
Rewards Points: 2,002
thank god you can recycle copper cause thats a waste of it right there
Tom Struble is offline   Reply With Quote
Old 07-26-2010, 03:16 PM   #9
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
That's a disaster. Have them, or a roofer clean that mess off the house and flash your chimney.
Sorry I don't take finished pictures. I take the detail pix and post them instead. http://www.albertsroofing.com/Chimney%20Repair.htm
tinner666 is offline   Reply With Quote
Bad job replacing chimney flashing? TNVolFamily Roofing/Siding 12 02-28-2010 07:04 PM
Chimney peak flashing richbl Roofing/Siding 5 09-29-2009 05:23 PM
Chimney Flashing mfitzsimons Roofing/Siding 4 04-20-2009 10:00 PM
Which flashing tape for Chimney flashing? gante Building & Construction 9 03-19-2009 10:27 AM
Looking for Chimney Flashing Kit. Prefabricated? gante Roofing/Siding 11 02-27-2009 09:11 AM
