Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing/Siding
Old 03-30-2005, 11:40 AM   #1
Proper Attic Ventilation
We live in southwestern Pennsylvania on a hill where it can be rather windy. We are going to replace our roof this year. We are considering having a ridge vent installed (AirVent ShingleVent II or an Owens Corning VentSure Externally Baffled). Our brick home is over 50 years old. There are two existing "gable vents", however, these vents located about halfway up from the attic floor and are rectangular, they are not the triangular type that are located right up by the rafters. If we combine this type of gable vent with a ridge vent would they be likely to cancel each other out? One contractor mentioned both a ridge vent and an attic exhaust fan. He also claims that the Owens Corning rolled ridge vent is better for a windy area.
Also, the roof has no overhang, so we cannot install soffit ventilation. Would a properly installed drip edge vent be of any help? Is there still a good chance for ice & water backup even if it is properly installed. We currently do not have any ice damming problems (plenty of insulation between attic and second floor ceiling).
We are also considering GAF Slateline or Owens Corning Oakridge 30 shingles. I'm not so sure the Oakridge singles would be good for a windy hill.
One roofing contractor claims that if we install any kind of gutter screening system, it will cause icicles.
Any experience or suggestions would be appreciated to help us make some decisions.
Thanks for your time....
kmhill35 is offline   Reply With Quote
Old 03-31-2005, 06:33 AM   #2
Commercial Roofing
AaronB's Avatar
Hi, I left a post for you at the first place you posted the ventilation questions.
Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 04-01-2005, 09:11 PM   #3
Grumpy's Avatar
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
Don't bother with a ridge vent if you can not install equal or greater soffit intake ventilation.
-Grumpy
Sometimes the savings that comes from doing it yourself can be blown away with one mistake.
The information found in this post is not to be considered legal advice. All information should be considered relative, not specific. Never attempt any repairs you are not comfortable with. Always maintain safety! The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
Proper Attic Insulation reikiray Roofing/Siding 5 08-04-2007 11:59 AM
Attic Ventilation - importance of balance FatAugie Roofing/Siding 7 08-04-2007 11:57 AM
Q? for Grumpy the Roofer re attic ventilation Ricky D Roofing/Siding 16 04-08-2007 02:19 PM
Attic Ventilation Questions AllGoNoShow Roofing/Siding 4 11-26-2006 01:02 PM
What is the proper ventilation needed? Ice Damns causing problems. alanisaacson Roofing/Siding 1 01-07-2005 02:38 PM
