Propanel Roof Paint - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-17-2010, 10:50 AM   #1
Question
Propanel roof paint
Hi there - Need input/advice on experiment..didn't see that one coming didya! I have a propanel roof with very slight pitch which makes snow removal slow at best even with roof rake. Want to paint about a 24" horizontal strip of black across the north side edge over hang of the roof to help with snow drop off. Do you think it will work and what type of paint should I use? Thanks for your help.
mwindsor is offline   Reply With Quote
Old 08-19-2010, 05:30 PM   #2
Grumpy's Avatar
Rewards Points: 552
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
It will likely work to paint the areas black where you want the roof to melt. I spoke with one guy who suggested on flat roofs, in the puddle areas, I paint the low spots black so the puddles melt first on the roof. From him it was salesmen bull chit, but it does hold merit. The one problem I see with that is, with a thick enough snow it will reflect the heat from making it to the black to warm the panels.
You can use a professional elastomeric roof coating if you want to prevent/stop any leaks.
-Grumpy http://www.illinoisroofinspections.com
The information found in this post is not to be considered legal advice. The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 08:00 AM
cheap paint in bathroom got mold? mayhem69 Painting 12 05-06-2012 04:46 PM
Ceiling paint versus wall paint billyg Painting 6 02-09-2012 07:38 PM
Replace the roof or not??? Leaked only once when it snowed chasqui Roofing/Siding 10 04-13-2010 10:02 PM
Paint riddle... Please help me fix this? techprincesse Painting 8 08-24-2009 10:00 AM
