Professional Roofers - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 12-24-2012, 07:40 AM   #1
Professional roofers
For my kitchen remodel, I need a vent cap installed for the hood. I asked for a cap for 6" duct. What I recieved was a cap with a 10" opening, a not so round 6" hole in the roof and the cap covering some of a stud!!
Aside from letting these jokers back on my property, what's my best solution for fixing a 6" duct to this mess?
Professional roofers-2012-12-23_08-54-54_992.jpg   Professional roofers-2012-12-23_08-52-03_673.jpg
OmegaWS6 is offline   Reply With Quote
Old 12-24-2012, 09:02 AM   #2
DIY staff
Rewards Points: 7,174
Wrong kind of duct cover---all you can do now is rig something up temporarily until you can get up there and change that to a 6 inch with a pipe flange and damper.
See if you can find a 12" square with a 6" hole----then a 6" duct adapter---that would get you through the winter.
Old 12-24-2012, 09:09 AM   #3
Rewards Points: 668
That looks like the same professionals, on a new house construction I saw, that put the vent holes in the sheathing with a claw hammer. I'm thankful I won't be around to see what has happened to craftsmanship 50 years from now.
Old 12-24-2012, 09:33 AM   #4
ParagonEx's Avatar
Rewards Points: 150
You're using the word professionals like they actually were supposed to be professional. Just because they do it full time and get paid for it, doesn't make them professional.
ParagonEx is offline   Reply With Quote
Old 12-24-2012, 09:39 AM   #5
Roofmaster
Rewards Points: 2,172
Those must be the same guys that break through the center of truss joists with a hammer to run plumbing and electric lines.
By the way what is it with the extremely long roofing nails sticking through your deck? Oops never mind, same guys.
If I did work like that, I would shoot myself, but I would probably miss.
Old 12-24-2012, 10:09 AM   #6
oh, mike. That's exactly what plan B is.
They did a "good job" changing three skylights at my parents house about a month ago, they are very happy with the work. I told my dad to not sit under any of them in case they come crashing down. He was not amused.
I am giving them the opportunity to install a correct style cap.. you know, one with a 6" lip for duct and CENTERED between the joists. Lets see if they can get it right the second time.
Old 12-24-2012, 10:15 AM   #7
Btw, those long roof nails are to make sure I bleed every time I go up into the attic!
Old 12-24-2012, 10:16 AM   #8
Roofmaster
Well tell them not to forget their deck stretcher to close up the bodaceous hole they cut by grabbing an alligator by the tail, and holing his head against your plywood.
PS Please be careful with those nails, ridiculous IMHO
Old 12-24-2012, 10:28 AM   #9
DIY staff
Depending on the style of vent--they could use the existing hole---the 6" duct doesn'tneed to clear the rafter by much---even using and 8" cover and bushing it down to 6" might avoid replacing shingles.
Old 12-24-2012, 10:49 AM   #10
Rewards Points: 13,228
It would be interesting to see what they did on the roof it's self to see if they even removed the shingles to do this.
Looks like they used a sawsall with a wide blade to make the hole.
Would have been so simple to have gone in the attic and driven a nail between the rafters, gone up on the roof and removed the shingles in that area, used a piece of string and a pencil to mark out the hole and use a jig saw to make that hole.
Old 12-24-2012, 02:24 PM   #11
Gymschu's Avatar
Rewards Points: 458
This might just be one of those cases where they used leftovers (vents, nails, etc.) from another job and used it on this job............all the while charging you for these mismatched items that another homeowner already paid for.
Gymschu is online now   Reply With Quote
Old 12-24-2012, 02:43 PM   #12
Ah, but they did drive a nail from the attic initially. Unfortunately it was too close to the upper? section of roof. Ray Charles then took his sawzall some random distance away and went to town. They were kind enough to hammer the nail back inside.
Old 12-24-2012, 07:27 PM   #13
RFN-4A-LVN
Roofmaster417's Avatar
Awe heck,,,what are you complaining about ? It takes more time to hack away at 10" versus a little 6 incher,,, Its called getting your money's worth. lmao
I would just call them back and have them fix it right,,,Your paying for a job done correctly.Here is what I would do.
Instead of trying to fix it yourself call them back and have them ;
1.Purchase the correct vent kit.
2.Remove the installed vent and shingles and felt exposing the decking.
3.Install new decking.
4.Follow manufacture directions for placement and installation.
5.Cut a new hole,,size as stated in the directions by the manufacture.
6.Install new shingles and seal the vent.
**Most IMPORTANT** At anytime you see any head scratching by your installer have them read the installation guidelines by the manufacture**
Roofmaster417 is offline   Reply With Quote
The Following User Says Thank You to Roofmaster417 For This Useful Post:
rossfingal (12-24-2012)
Old 12-24-2012, 07:53 PM   #14
Rewards Points: 2,238
"Roofmaster417"
That's too simple!
I thought it was "rocket science"!!
"RF"
Happy Holidays!
rossfingal is offline   Reply With Quote
The Following User Says Thank You to rossfingal For This Useful Post:
Roofmaster417 (12-24-2012)
Old 12-24-2012, 08:14 PM   #15
RFN-4A-LVN
Originally Posted by rossfingal View Post
"Roofmaster417"
That's too simple!
"RF"
Happy Holidays!
Hey ritbakatcha,,Wishing you and your family a very Merry Christmas,,,,Yeah,,,I know them instructions are just too damn complicated.I mean how many steps could there possibly be ?
1.Remove vent from box. (That's a hard one)
2.After removing vent locate paper with instructions.That's the 8" by 11" white piece of paper showing all the tools you need for installation,a picture of the vent,roof,hole etc.
*Tip* One side is in English and the other is in Spanish.Keep flipping the paper until you find a word that looks familiar.
*Tip* Locate a vent that is suitable for up to a 6" opening.
*Tip* Make sure there is "For use up to a 6" opening somewhere on the box.
Is it common for roofers to NOT slice underlayment on a ridge vent before installing? jcarlan Roofing/Siding 29 01-05-2012 04:26 PM
Professional standards nothandy1 Flooring 7 06-15-2011 08:02 AM
How to find a professional Wanderer General DIY Discussions 15 05-09-2011 04:32 PM
Honeywell DIY or Professional thermostat? beiley HVAC 0 09-10-2009 12:06 AM
DIY versus Professional Hemingway General DIY Discussions 25 02-26-2009 10:30 AM
