Which Product To Use For Roof Maintenance? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 11-14-2013, 02:19 PM   #1
Rewards Points: 682
Which product to use for roof maintenance?
I plan to recover some bare spots on my flat roof with gravel. I was planning to use Henry #204 to make the gravel stick. Is this a good idea?
Also one of the roof vent pipes had an antenna attached to it, the wind blowing on the antenna loosened its bond with the flashing. I was planning to patch this with henry #204. Again is this the right product?
darsunt is offline   Reply With Quote
Old 11-18-2013, 11:39 AM   #2
Low Slope Roofing
Rewards Points: 114
Should be fine for both, patching will require some sort of reinforcing fabric though. THe mastic alone doesn't have much strength.
1985gt is offline   Reply With Quote
Old 11-19-2013, 02:03 PM   #3
Rewards Points: 682
Thanks. I'd forgotten about the fabric.
AC Not cooling like it should...maintenance guy gives up...help! b1ackcat HVAC 21 12-24-2015 11:54 PM
Preventive Maintenance - Swere Rodding majch Plumbing 6 05-02-2012 08:51 PM
Roof Maintenance Package majch Roofing/Siding 6 03-31-2012 01:11 AM
EDGE Tile Flooring Product dianedodson Tiling, ceramics, marble 2 11-01-2011 07:39 PM
Toyota Highlander maintenance dinosaur1 Automotive Repairs 10 02-21-2011 01:55 PM
