Problem With Ridge Vent - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-30-2009, 11:28 PM   #16
You are not understanding the plywood repair as prescribed.
Also, I looked up the Omni Ridge Vent Lo Profile one you mentioned. I like their regular 4 foot sectional versions, but that Lo Profile only offers 11 square inches of NFVA per foot, when most brands, like the Cobra Snow Country or Advanced and also the Shingle Vent II, each offer 18 square inches per lineal foot.
That is way too much of a sacrifice on ventilation specifications for most homes I have run the calculations on to be satisfied with, but you were correct about it being gun nailable.
Ed
LOR9-4 Shingle Over Ridge Vent
Optional Pneumatic Nail Gun or
Hammer Installed.
Internal Aerodynamic Curved Baffles.
External Perpendicular Omni Baffles.
Weatherproof Underlapping Joint.
Four Drain Holes per Foot per Side.
11" Net Free Area per Linear Foot.
External Venturi Baffle.Adjust from 3/12 to 16/12 roof pitches.
Nail Holes Marked Every 6 inches - Supported Every Foot.
Molded Nail Lines.
Molded Centerline for Fast and
Easy Alignment.
Alignment Tabs.
External Water Shield.
Slot Width Guide Lines.
Patented Molded-in Fanfolded Endplug Fits.
30-year transferable warranty.This is an exhaust louver.
Ed the Roofer is offline   Reply With Quote
Old 07-01-2009, 06:36 AM   #17
Rewards Points: 258
Magic,
Please let us know how the problem is eventually resolved.
retired guy 60 is offline   Reply With Quote
Old 07-01-2009, 06:39 AM   #18
MJW
I reread your post Ed, and understand what you are talking about. It would just require a few more rows of shingles to be taken off, but would work well.
Never had a ventilation problem with the omni roll. Have used it on many houses including my own.
GAF claims over 14 NFVA on their regular Cobra vent, but I have seen where it actually is one of the worst ventilators in comparison tests. The problem with the ventilators that have the webbing in them is that they get dirty and lose their claimed performance. Moisture collects and dirt sticks. Good idea, just is slowly being proven not to work in the long run.
MJW is offline   Reply With Quote
Old 07-01-2009, 05:49 PM   #19
I agree with personal observations about the Cobra Roll Vent, the one that looks like a brillo pad or furnace filter type material.
I see those clogged with algae growth, showing that no air flow is warding off the growth and that moisture remains inside the structure.
I have not seen that problem on Shingle Vent II on ridge vents I installed over 10-12 years ago that I have checked up on though.
I am glad that you reread the plywood repair so that you knew what I was talking about.
Ed
Old 07-06-2009, 11:38 AM   #20
Fixed
Well after 20 calls to GAF putting a stop payment on his check and sending a certified letter. The owner came out and met with the inspector and then came the next day and repaired everything. Why he changed his mind I don't know but it is fixed and I am happy and it was fixed before our big storm this weekend. No leaks....
Thanks for all your input.
magic is offline   Reply With Quote
Ridge vent Plus roof fan? mano Roofing/Siding 6 06-30-2009 02:59 PM
Adding attic vent w/existing ridge vent GeorgiaGeek Roofing/Siding 6 05-05-2009 02:04 AM
best ridge vent? ponch37300 Roofing/Siding 4 07-23-2008 08:00 PM
Problem with whole house fan and not enough attic/roof vent area keeena Roofing/Siding 11 06-16-2008 11:59 AM
Ridge Vent on a Shed jokiddjr Roofing/Siding 5 03-14-2008 03:22 PM
