Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 11-28-2011, 01:11 AM   #1
probably a unique question!
hi to everyone,
i am building (or attempting to guide) the building of a resort in the andaman sea on the thailand coast. problems are many as are the choices. i am not a builder or skilled in DIY. (feel free to abuse me etc 'what the hell are you doing' etc.....)
anyway back to the subject. i have built three houses on a sandy/soil peninsular ...the architect assures me the foundations will be solid :-)
they are breeze block two floor construction 45 sq metre floor area.
this is my question. i want to keep the roof light and strong. i have the idea to use green board over the metal roof skeleton over this the local grass 'sheaves'. this grass sheaving is quite hard wearing (ive used it on 7 units of a lesser quality already)
thermal properties are what im interested in
1. does green board 'breathe?
2. what are the water/rain protection properties like?
3if a metal roof skeleton is going to expand with heat (frequently 40 degrees centigrade here ....120 F ... will the greenboard crack?
4. anyone ever done this before?
if i use tile (here in thailand its a thick heavy cement tile with a wave called CPack...... im sure the weight plus heat retention will make the house an oven!
i am on an island, my builder is a local there is no one here with a knowledge of materials etc ....its all pretty basic ... so easy and simple are the key elements to good choices
thanks in advance to anyone who has the time to reply :-)
andaman
andaman is offline   Reply With Quote
Old 11-28-2011, 08:27 AM   #2
Exterior Construction
Windows on Wash's Avatar
Make sure you get a vapor barrier under the foundation.
By green board, do you mean a zip wall sheathing?
I am not sure what the perm rating on the Zip panel is but it is probably near what OSB is at around 5. You should not have a vapor barrier in your climate if I were going to hazard a guess.
OSB is temperature stable to pretty high temps so you should be more than fine.
Go with a high solar reflectivity metal.
Tags
grass, heat, roofing
DRIcore question trailblazer1229 Flooring 0 02-24-2010 10:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 01:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 09:24 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 05:36 PM
hrv question indep HVAC 3 07-17-2008 11:39 PM
