Priming For EPDM - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-14-2011, 07:48 PM   #1
Priming for EPDM
Hi folks!
I have a flat roof deck (living quarters underneath) that I have had to re-frame after years of wood rot. So, for the top, I've decided I will use EPDM.
My question is, what can I use to prime and seal the sheathing, that the EPDM and adhesives will properly bond to? I would like the roof sealed BEFORE adding the rubber, just so I know if I got a small tear in the EPDM, havoc would not break out.
Also have two sections with aluminum flashing, can I just use a metal primer for those, s the adhesive will stick? It is not bonderized.
One other question, will Pointing Mastic damage EPDM? It is Xylene based.
Thank you
ctedone is offline   Reply With Quote
Old 09-14-2011, 10:55 PM   #2
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Priming for EPDM
I'm not aware of any sealer that will be compatible with EPDM glue. And if you go straight to plywood, plan on picking out the splinters lifted by the glue to avoid punctures, and at the least, plenty of lumps and bumps from wood slivers under the EPDM.
"One other question, will Pointing Mastic damage EPDM? It is Xylene based." Does it say "Made for EPDM?" If not, I'd bet on plenty of damage.
tinner666 is offline   Reply With Quote
Old 09-15-2011, 07:47 AM   #3
Residential Roofer
Slyfox's Avatar
Priming for EPDM
Rather then spending time and money sealing the sheathing, spend it on fastening an 1/2" of recover board/fiber board to the sheathing with plates & screws.
All metals should be primed before covering them.
You will be using to different glues:
1. Bonding Adhesive, which will be applied to the fiber board, epdm and walls.
2. Seam adhesive, for seams, flashing's, etc.
Use a soft push broom to run across the epdm after glue/laid down.
Use a hand roller on flashing's, seams, etc.
Don't forget to caulk all laps with a lap sealant, this will prevent dust/moisture from getting into the seams while they go through the curing process.
If you have a need for termination bar, etc., use some water block 'caulking' between the metal and the structure.
God Family Country Work Play
Facebook <> Twitter
Slyfox Exteriors Co.
Slyfox is offline   Reply With Quote
irrigation pump shutdownMy Sta-rite 2 HP centrifugal self priming single phase 240V i Oly Electrical 7 06-17-2010 11:44 AM
Priming Interior Wood Doors Lovegasoline Painting 6 09-12-2009 04:48 PM
Caulking...Priming & Painting with Tape saggdevil Painting 3 05-19-2009 11:42 AM
Painted semi-gloss over semi-gloss without sanding or priming -- now what? ShrimpBurrito Painting 7 03-18-2009 07:50 PM
Finished priming, but I still see shadows underneath...? yummy mummy Building & Construction 2 02-19-2009 09:15 AM
