Power Gable Vents VS Ridege Vent - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-14-2011, 12:40 PM   #1
Power gable vents VS ridege vent
I own a 2100 sf house in Florida that I am desperately trying to cool off. In the middle of summer it is not uncommon for my house to be 80 degrees inside. The house and AC are only 5 years old. The AC installers have said the AC is of the correct size and working fine. THe only venting I have in the attic is the static gable vents. What would be better given the situation, motorized gable end vents, one on each end of the house, or ridge vent running the length of the house? My soffits are perforated vinyl and are 360 degrees around the house. Any info would be greatly appreciated.
USNavychief is offline   Reply With Quote
Old 07-15-2011, 09:35 AM   #2
AGWhitehouse's Avatar
Make sure that there is at least 1" clearance between your roof sheathing and the insulation in your attic. If there isn't then get some venting panels (Lowes, Home Depot, or equal has them) and install.
If you do this and it doesn't help or if you have the air space already, then there are two things you can do:
Install gable end louvers on each end and put a powered fan with thermostat and humistat. This will move air through your attic when temperatures get too high. At the same time, install Tyvek or equal over the top of your insulation (what I assume is fiberglass). Air movement through the fibers greatly reduces the effectiveness. By putting and air barrier (NOT a vapor barrier) you will bring the insulation into it's optimum effectiveness.
AGWhitehouse is offline   Reply With Quote
Roof ventilaton - hip roof (ridge vent, fan, power vent ?) rkpatt Building & Construction 2 06-02-2011 04:21 PM
Old Work Gable Vent obricko Roofing/Siding 0 05-21-2011 10:53 AM
Replace Power Vent? Cmeller Roofing/Siding 1 05-16-2011 04:20 PM
power vent d.c.patel HVAC 1 04-27-2011 09:02 PM
Shingling over ridge vent -details needed jogr Roofing/Siding 4 11-06-2009 05:47 PM
