Posting Tar Paper - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-11-2011, 11:52 AM   #1
Rewards Points: 1,062
Question
posting tar paper
this sounds rudimentary but is there any specific things that are not completely intuitive about posting tar paper on a roof? it is a small shed (11x9). i was just gonna use asphalt felt 15 (as opposed to 30, is that OK?) and post rows going vertical (i.e. perpendicular to the ridge beam) and lap each row by maybe an inch or so to avoid having exposed slots. was gonna use a swing stapler and 0.5" staples. does this sound like the right approach?
thanks
Old 03-11-2011, 12:03 PM   #2
Not so new
12penny's Avatar
Rewards Points: 520
...is there some advantage to running it vertical?
12penny is offline   Reply With Quote
Old 03-11-2011, 12:42 PM   #3
i was thinking it would be better for joints between rows to run vertical to avoid possible leakage between them but then again, if you run them horizontal and lap the next row up over the one below, that might even be better.
Old 03-11-2011, 12:50 PM   #4
Rewards Points: 52
Horizontal, with minimum 4" lap, and your 1/2" staples, and you'll be fine. Just be sure to keep it flat to the sheathing as you roll it out, so that you don't have humps under your shingles. I seem to recall you asking about ice guard in an earlier post, and, again, if there is enough for your shed in a roll, you could just run that up the roof, in place of felt. If you do that though, don't staple it.
The Following User Says Thank You to DexterII For This Useful Post:
amakarevic (03-11-2011)
Old 03-11-2011, 01:04 PM   #5
Question
thanks, is felt #15 OK ?
Old 03-11-2011, 01:04 PM   #6
waterman1971's Avatar
Rewards Points: 150
We have torn them off years ago where the roofers followed the valley lines?
waterman1971 is offline   Reply With Quote
Old 03-11-2011, 01:06 PM   #7
Question
huh? torn what and what valley lines?
Old 03-11-2011, 01:09 PM   #8
Rewards Points: 52
You could ask your local building authority, but, personally, I would be more inclined to use 30, simply because it is a shed, and therefore the tendancy down the road may be to extend replacement of it as long as possible. Not that 30 is necessarily going to help at lot at that point, but it might. Just an opinion.
Old 03-11-2011, 02:11 PM   #9
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
#15 is fine. Run it horizontally.
seeyou is offline   Reply With Quote
The Following User Says Thank You to seeyou For This Useful Post:
Old 03-11-2011, 03:11 PM   #10
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Look at the directions on the shingle wrapping.
They always show tarpaper and they always show it run horizontally.
tcleve4911 is offline   Reply With Quote
The Following User Says Thank You to tcleve4911 For This Useful Post:
Old 03-11-2011, 05:57 PM   #11
Registered User
Rewards Points: 5,212
Be sure to use roofing felt for roofs rather than tar paper for siding. Many don't know or think there's a difference; http://www.fortifiber.com/pdf/fortif...sk_vs_felt.pdf
http://www.dickseibert.com/martin.pdf
Gary
Gary in WA is online now   Reply With Quote
The Following User Says Thank You to Gary in WA For This Useful Post:
amakarevic (03-12-2011)
Repairing stucco felt paper titan7 Building & Construction 5 02-26-2011 09:44 PM
why does starter strip have glue on it if it goes on tar paper? KarlJay Roofing/Siding 4 11-24-2010 03:05 PM
Felt Paper and the Sun. Valley problems hartkem Roofing/Siding 1 07-22-2009 04:57 PM
contact paper removal scatterbrain Remodeling 2 07-06-2008 08:57 AM
