Possible Water Damage - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 11-07-2011, 02:16 PM   #46
Hi guys. I have decided to fix the roof myself. Sure I could sue the builder, but even if I would win, I would have to pay a large lawyer fee, and there is no guarantee that the new roofer who repairs my roof will do a good job. If you want something done right, you have to DIY. I am sure the cost of DIY will be cheaper than a lawyer fee.
The tiles are easy to remove because they are not nailed down. They are just resting on battens. I plan to remove all valley tiles, plus any tiles that have deteriorated felt under them. I will remove battens and replace the old felt with Grace Triflex underlayment using cap nails. Then I will replace the battens and put the old concrete tiles back on. I will also place Grace Triflex underlayment under the valley metal flashing.
If I happen to do a lousy job, I can always hire a roofer later to correct my work.
Is there any way to replace underlayment without removing the battens?
Here is my roof in 2003 when the house was being built.......
mike932 is offline   Reply With Quote
Old 11-08-2011, 07:43 AM   #47
Rewards Points: 582
Good luck with the job.I don't know any way of replacing the felt without taking off the battens.
You must use a different way of felt and batten to us. Here we would counter batten the boards so the felt is loose and allows water to run under the battens to the eaves. Your's looks like there is a gap in the battens to let it through.
stuart45 is offline   Reply With Quote
Old 11-08-2011, 08:22 AM   #48
Chicago, IL
Michael Thomas's Avatar
Unfortunately they are not available on line, but the standard references for tile roof installation are produced by the Tile Roofing Institute.
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 11-08-2011, 07:19 PM   #49
I started my mission today. Removed tiles from the valley and the leaky area. Found the leak. Water seeps between 2 sheets of OSB board near the gutter. Felt is rotted in the leaky area. I plan to seal the leaky area with ice and water shield.
Old 11-08-2011, 07:49 PM   #50
What do you guys think of this idea?.... I am going to replace the rotted felt with ice and water shield, and I will replace the rotted battens with new battens. I am trying to figure out how to remember where the rotten battens were (before I remove them). I could measure the location of the battens before I remove them, but I think I have a better idea. I am going to nail cap nails adjacent to the rotted battens before I remove them. This will mark their location. I will remove the rotted battens and felt, and then put ice and water shield on. Then I will use my finger to feel where I put the cap nails. This will tell me exactly where to place the new battens. Is this a good idea, or is there a better solution?
Old 11-09-2011, 10:43 AM   #51
Rewards Points: 582
you can also make a batten gauge from a piece of batten that will fit in between the battens at the correct measurement.
The Following User Says Thank You to stuart45 For This Useful Post:
tinner666 (11-09-2011)
Old 11-09-2011, 01:10 PM   #52
I think the tiles in the valley are channeling water from the valley to the felt on the sides of the valley. This would had been avoided had the builders chosen to build an open valley instead of a closed valley. I am thinking about placing lego pieces under the valley tiles to elevate the tiles enough to allow water to flow under them.
Old 11-09-2011, 09:49 PM   #53
By the way, there is no drip edge on my roof. Is this common with concrete tile roofs?
Old 11-16-2011, 07:29 PM   #54
I finished the roof. Put a layer of ice and water shield over the leak. I also installed a drip edge. My only mistake was not keep track of which tiles were which. I put them back together slightly out of alignment.
Old 11-17-2011, 06:56 AM   #55
Rewards Points: 2,238
Check the flashing on the chimney!
Probably, should be some type of drip edge.
rossfingal
rossfingal is offline   Reply With Quote
Old 11-17-2011, 03:05 PM   #56
chimney has flashing.
Water damage. How bad can it be? alexin General DIY Discussions 3 08-23-2010 01:53 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
Very Low Hot Water Pressure. PAS1970 General DIY Discussions 2 02-25-2009 03:01 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
