Is It Possible To Attach A Gutter To A Roof That Has No Fascia? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-16-2014, 01:37 PM   #1
Rewards Points: 1,584
Is it possible to attach a gutter to a roof that has no fascia?
There is this house I am not sure how the soffit was constructed, where normally you would have fascia wood boards behind the drip edge, it is a rounded bottom. Hard to explain but here are some pictures.
How would you install a gutter along the front side of this roof?
miamicuse is offline   Reply With Quote
Old 04-16-2014, 10:16 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 854
Yes. Requires a bit more forethought and you are going to need a good sized drip cap/edge to kick the water out.
Old 04-16-2014, 10:41 PM   #3
iminaquagmire's Avatar
Rewards Points: 338
They do make brackets that attach under your roofing. If under shingles, I'd want ice and water shield there first since they don't attach very high on the roof.
iminaquagmire is offline   Reply With Quote
Old 04-26-2014, 08:35 PM   #4
Roofers Advice
Roofers Advice's Avatar
Do you have any other pictures that show the top of the roof?
Roofers Advice is offline   Reply With Quote
The Following User Says Thank You to Roofers Advice For This Useful Post:
ben's plumbing (04-26-2014)
Old 04-28-2014, 01:02 PM   #5
Low Slope Roofing
Rewards Points: 114
If that's a flat roof like the other section there should be a nailer there. Even if it's shingles there has to be something there.
1985gt is offline   Reply With Quote
Gutter installation questions Homerepairguy Roofing/Siding 7 03-15-2012 11:22 AM
Yankee gutter resurfacing options miamicuse Roofing/Siding 24 01-06-2012 09:20 AM
Gutter apron - new roof question Slyguysmoke Roofing/Siding 1 04-21-2011 11:00 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 05:08 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 07:17 AM
