Portico Rubber Roof - Vinyl Post Installation? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-06-2009, 08:58 PM   #1
portico rubber roof - vinyl post installation?
Could you give some suggestions on the best/easiest way to install/fasten a vinyl post on top of my front entrance portico, flat rubber roof?? Existing wooden railing system and posts are rotted and I want to replace with vinyl system. Don't know whether to sleeve the vinyl post over a toe-nailed 4 X 4 or use a metal installation kit, or what?
Hate to penetrate the rubber roof membrane, but must figure out best way to do it. Builder apparently toe-nailed the 5 X 5 wooden posts in, seemingly without caulking or flashing around the bases, now rotted.
Ed
Ed Salsbury is offline   Reply With Quote
Old 09-04-2009, 11:21 AM   #2
Same issues
I have the same issue although the leaking came from poor flashing where my portico attaches to the house. I have to replace a bunch of rot. When I do I want to put up vinyl railings without penetrating the rubber roof membrane. I hope someone out there can answer this question...
Ed
davsinc2007 is offline   Reply With Quote
Old 09-05-2009, 10:38 AM   #3
Roofing Contractor
Leftyho's Avatar
Hi,
It is impossible to put railings up without penetrating the roof.
Fairway makes metal inserts for the posts. This is the easiest way to get it water tight.
Leftyho is offline   Reply With Quote
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 08:33 PM
Porch Enclosure Vinyl post stillworking Carpentry 1 03-18-2008 06:07 PM
porch post vinyl or metal to stop painting? hobbyguy2002 Building & Construction 2 01-28-2008 04:37 PM
