-   -   portico rubber roof - vinyl post installation? (http://www.diychatroom.com/f9/portico-rubber-roof-vinyl-post-installation-48250/)
Ed Salsbury 07-06-2009 07:58 PM
Could you give some suggestions on the best/easiest way to install/fasten a vinyl post on top of my front entrance portico, flat rubber roof?? Existing wooden railing system and posts are rotted and I want to replace with vinyl system. Don't know whether to sleeve the vinyl post over a toe-nailed 4 X 4 or use a metal installation kit, or what?
Hate to penetrate the rubber roof membrane, but must figure out best way to do it. Builder apparently toe-nailed the 5 X 5 wooden posts in, seemingly without caulking or flashing around the bases, now rotted.
Ed
davsinc2007 09-04-2009 10:21 AM
Same issues
I have the same issue although the leaking came from poor flashing where my portico attaches to the house. I have to replace a bunch of rot. When I do I want to put up vinyl railings without penetrating the rubber roof membrane. I hope someone out there can answer this question...
Ed
Leftyho 09-05-2009 09:38 AM
Hi,
It is impossible to put railings up without penetrating the roof.
Fairway makes metal inserts for the posts. This is the easiest way to get it water tight.
