-   -   porch cover - flashing question (http://www.diychatroom.com/f9/porch-cover-flashing-question-183723/)
garya505 07-16-2013 05:09 PM
I am making a plan for a porch cover addition to my house. The house is stucco like 99% of the homes around here. The porch cover will have a metal roof which is also very common here. I have a question about how this metal roof is usually flashed to the stucco. The problem I have is that I have read about the correct way to do it (inserted under the stucco), but then I look around and have seen none that are done that way. I've seen probably 100 or so, all just stick on the surface (I can see the sealer on the top edge). The many I have seen are done with a flashing or endwall with a flared top edge, just adhered to the stucco with some kind of silicone or something. I understand that this is not the right way to do it, so why do I see none done that way? Could it be our low rainfall (about 9 inches per year)?
AndyWRS 07-17-2013 11:05 PM
Behind the stucco is ideal but surface mounting is fine so long as they do it properly.
I like something like this:
http://www.fryreglet.com/details/roof/pop/164.htm
jagans 07-21-2013 02:57 PM
Its called a surface mount flashing. Its no good, it never has been any good, and it never will be any good. In Boston its called a Philadelphia Flashing. In Philadelphia its called a Boston flashing, and in the NRCA,the RCI, and SMACNA its called She-Hit.
tinner666 07-22-2013 05:40 AM
And here we have a winner. Jim is correct. Tear/cut out 8" of stucco, do roof and flashing, repair the stucco.
Sounds like a lot, huh? Do it the other way and when you have to make repairs and fix a lot of rotted wood for nearly, or even more than what the roof originally cost, you'll see the true benefit of doing it correctly the first time.
garya505 07-26-2013 11:43 AM
I hear what you're saying. After I posted this I have looked at a few more around here, and almost all of them are done on the surface. I suspect the reason why people get away with it around here it because it's so dry most of the year. In fact, now that I think about it, I have never heard anyone talking about rotted wood around here, due to any cause.
