Poor Venting Caused Brown Stain? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 01-08-2012, 10:15 AM   #1
Poor venting caused brown stain?
Hi all, I took a hot shower last night and half way through the shower I noticed a small brown stain on my bathroom ceiling. Initially I thought I had a roof leak but it's bone dry outside and no pipes above. Could this be condensation finally catching up? The bathroom is very small ( with a mediocre venting fan) and gets steamy easily.
I'm thinking it's something with the paint reacting to the constant moisture?
Attached is the pic of the stain: it looks bigger in the pic but really about 2-3" diameter.
Thanks all!
Stefanie
MikePet is offline   Reply With Quote
Old 01-08-2012, 10:55 AM   #2
Hi all, I took a hot shower last night and half way through the shower I noticed a small brown stain on my bathroom ceiling. Which im certain wasnt there when i got in Initially I thought I had a roof leak but it's bone dry outside and no pipes above. Could this be condensation finally catching up? The bathroom is very small ( with a mediocre venting fan) and gets steamy easily.
Please note the house was very humid because we had 60 degrees yesterday , and the few days before we're freezing.
Old 01-08-2012, 12:27 PM   #3
Rewards Points: 1,192
Poor venting,Vent outside?
bobelectric is offline   Reply With Quote
Old 01-08-2012, 12:29 PM   #4
Hi bob, yes it vents outside. Just took a hot shower again and noticed that spot looked moist again.
My husband is away for a month so I'm trying to figure this myself.
Thank you!
Old 01-08-2012, 12:41 PM   #5
iminaquagmire's Avatar
Rewards Points: 338
When its cold outside and cold in the attic, chances are you'll have a cold exhaust duct for the fan too. If the fan isn't strong enough to exhaust the warm moist air outside before it condenses on the cold pipe, you can get what you have when the condensation comes back down the duct. The solution is to 1) make sure your fan has good pull, 2) you have insulated ducting for the fan exhaust, and 3) there are no dips or bellies in the exhaust pipe that can collect condensation.
iminaquagmire is offline   Reply With Quote
Old 01-08-2012, 12:55 PM   #6
Thanks quag. What gets me is why only on this one spot? Is it because it's right next to the shower and bathroom fan? That's where most of the heat moisture goes ( that spot)
Old 01-08-2012, 01:06 PM   #7
Rewards Points: 338
Could be the design of the fan. Most fans have the exhaust port on the side of the fan housing.
Old 01-08-2012, 01:45 PM   #8
Rewards Points: 13,270
If there's a bare spot in the insulation that spot would be colder and water would condenice there first.
Have you more the insulation back in that area to see if it wet on the top side of the drywall? If the insulations wet and the top side is wet then it's a leak from above.
Old 01-08-2012, 01:48 PM   #9
DIY staff
Rewards Points: 7,174
Two likely causes---condensation in the vent fan tubing---leaking back and staining from on top--
Insulate the vent pipe after you replace the old leaky one--
Or--Missing insulation above the stained spot causing condensation right there---add insulation.
Old 01-08-2012, 01:51 PM   #10
Hasn't rained in ages. Roof is bone dry. Haven't gotten to insulation because I haven't ripped ceiling open. Hoping to avoid that
Old 01-08-2012, 06:28 PM   #11
I think it's weird that this issue occurred on a day we unusually got 60 degree weather after a week of really cold weather. Doesn't help my bathroom is very very small
Old 01-09-2012, 08:19 AM   #12
I noticed the ceiling paint used is probably a standard white, wall paint. If I get a damp cloth and move my finger on it , paint comes right off.
Old 01-09-2012, 08:20 AM   #13
I noticed the ceiling paint used is probably a standard white, wall paint. If I get a damp cloth and move my finger on it , paint comes off, fairly easily. And I'm not talking about the spot where there is a stain.
Old 01-09-2012, 08:30 AM   #14
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,798
Need to see/know about the attic conditions.
  1. insulation
  2. venting
  3. bath fan venting
  4. etc.
The Following User Says Thank You to Windows on Wash For This Useful Post:
oh'mike (01-09-2012)
Old 01-09-2012, 08:43 AM   #15
DIY staff
Get us a few pictures from above--that's where the problem is---
Fiberglass door, gel stain, and nervous breakdown wit's end Painting 8 10-26-2011 11:10 PM
Removing stain from deck machouinard Painting 20 09-08-2011 10:12 PM
Deck stain project gone bad - HELP brownnl Painting 13 03-15-2011 02:57 PM
Perfect stain mix for dark chocolate brown floor finbriar Flooring 2 04-14-2009 07:19 AM
Need advice on removing deck stain mwalt2 Painting 7 07-23-2008 06:51 AM
