Pool Safe On Roof Deck? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-21-2009, 12:06 PM   #1
Pool safe on roof deck?
We have a roof deck on a Brooklyn brownstone building, built over iron joists of course, and are wondering if the deck could support a small portable plastic pool, about 8 ft long and 30 inches high.
Some have said water makes everything too heavy, others have said it's fine.
catbird is offline   Reply With Quote
Old 05-21-2009, 01:21 PM   #2
Rewards Points: 356
I would only trust the opinion of structural engineer that closely inspected the building. You say 8' long... if it is 4' wide x 8' long x 30" high just the water would be approximately 5136 lbs which would be much weight in a concentrated area for most structures.
RegeSullivan is online now   Reply With Quote
Old 05-21-2009, 09:02 PM   #3
You need to find out if your structure is engineered to hold that much weight in water.
I think it would cause other problems as well.
Ed
Ed the Roofer is offline   Reply With Quote
Old 05-22-2009, 07:49 AM   #4
thanks! sounds like it probably won't work.
Extend House Roof Over Back Deck Justahome Carpentry 17 04-05-2009 03:42 PM
Extend House Roof Over Back Deck Justahome Carpentry 1 04-03-2009 07:25 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 04:08 PM
