Ponding On Flat Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 12-07-2006, 04:00 PM   #1
ponding on flat roof
can anyone tell me how to stop ponding on the flat roof ? i have a flat roof after rain the water still stay on it (about 3 inches of water). I don't want to re-deck it. can i pour gravel on it. Please advice . thanks
workman is offline   Reply With Quote
Old 12-07-2006, 04:49 PM   #2
How large is the pool of water? (diameter)
Is there a drain on this roof?
redline is offline   Reply With Quote
Old 12-07-2006, 05:09 PM   #3
I have two words for you.....
Portland Cement
Keep sprinkling it till the roof is flat again. How effortless is that?
I was going to suggest drilling a hole.
Wish it away?
pmaru77 is offline   Reply With Quote
Old 12-08-2006, 09:24 AM   #4
sorry I wasn't clear enough!
my flat roof is rolled roofiing. look like it curve in the center that why the water stay on it. the diameter is about 10 feet. i wonder can i put some kind of foam or wood on it and re-roof on this area. Thanks
Old 01-31-2007, 11:51 AM   #5
Commercial Roofing
AaronB's Avatar
Have a commercial flat roofing company come out assess the situation, and install a roofing system. You can eliminate ponding with tapered insulation saddles before the waterproofing goes on. Depending on the type of roofing and it's condition, you may be able to do this now, and cover over it with compatible a roofing membrane.
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 02-11-2007, 12:30 PM   #6
Rewards Points: 150
another cost effective solution that in some cases works great is to work with a plumber and a commercial roofer to install an interior roof drain. You can put it in the natural low area and an interior drain never freezes up like a scupper or gutter can. We have done this on several commercial jobs and it solved the problem without reroofing.
RooferJim
www.jbennetteroofing.com
RooferJim is offline   Reply With Quote
Old 02-12-2007, 07:45 AM   #7
Commercial Roofing
AaronB's Avatar
..or what Jim said.
Old 02-12-2007, 08:11 AM   #8
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
Or, if its new, have the original roofer come back and do the job correctly!
Brik is offline   Reply With Quote
Old 02-16-2007, 03:58 PM   #9
Commercial Roofing
AaronB's Avatar
Do you mean correctly or according to what the customer is willing to pay? Lots of times customers don't want it "right" if they can get something "cheaper".
Old 02-17-2007, 05:05 PM   #10
remodeling pro
I'm sure that my usual answers to most people wanting some kind of flat roof fix are not what they want to hear, but here goes again. Call a good roofing company used to dealing in flat roof work. Have it fixed correctly once and be done, or half ass it and be repairing leaks and damage to whatever is below this roof forever. They can elimainate the low spots with foam decking as previously mentioned, and apply a better waterproofing than "roll roofing" . For a flat roof to be successfull, it must be done correctly, and is not a project for a novice...refer to the suggestion that you sprinkle the area with portland cement . That's scarry.
troubleseeker is offline   Reply With Quote
Old 10-21-2011, 05:02 AM   #11
Originally Posted by The Roof Medic View Post
If you don't want to re-pitch and re-deck install a solar roof pump- go to www.SolarRoofPumps.com they are in expensive and work!
Wow..thanks for helping the o/p out.he was probably still sitting at his pute (years later)just waiting for the right product.U aren't a spammer,r u?.Now don't come back u hearoff
johnk is offline   Reply With Quote
The Following User Says Thank You to johnk For This Useful Post:
federer (10-21-2011)
Old 10-21-2011, 11:49 AM   #12
Rewards Points: 978
i am getting a little bit of staining on the edge of my flat roof
federer is offline   Reply With Quote
Old 10-21-2011, 05:54 PM   #13
Ponding on a flat roof
I'm not an expert, but my church decided to put an addition on top of an already flat roof. We've had a bad ice storm a year ago and between the weight of the ice and the length of time it took to melt, the interior ceiling shingles were water stained. So, there is no benefit in building a flat roof. However, just like you, we are in the process of repairs, so I suggest seeking out reputable Portland roofing contractors to get some kind of run-off from the room (and go "green" and collect the rain water at the base).
DIYKaren is offline   Reply With Quote
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
flat roof leak snikda9 Roofing/Siding 16 01-26-2006 04:25 PM
Flat Roof Replacement Quote Questions rocketmahn Roofing/Siding 1 01-02-2006 06:01 PM
Need Help on the Flat Roof and more... MelindaA Roofing/Siding 12 12-21-2005 10:12 PM
Where flat roof meets shingled roof bstyer Roofing/Siding 1 07-07-2005 08:34 PM
