Polishing Up A Skylight. - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-11-2013, 01:49 PM   #1
Rewards Points: 101
Polishing up a skylight.
I'm putting this under roofing, because I can't figure where else to put it!
We have a skylight over the kitchen in our house which provides the only direct natural light to the area. However it's still pretty murky unless the sun is hitting the skylight directly, and much of the problem is that the skylight itself has become very clouded and dirty over the years. The dirt I can clean, but the cloudiness is something in the surface (just like old headlights on cars) and I was wondering if I could use the same stuff they sell for headlights to polish the skylight surface up to make it a little clearer. Anyone else gone down this path?
If it doesn't work I guess I'll just have to bite the bullet and buy a new one to put in place.
timbo59 is offline   Reply With Quote
Old 04-11-2013, 01:58 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 2,124
If it is an acrylic/plastic, the plastic polishes should work.
Might be worth just biting the bullet on a new unit that is clear and more insulated to boot.
Is it a curb or deck mounted unit?
The Following User Says Thank You to Windows on Wash For This Useful Post:
joecaption (04-11-2013)
Old 04-11-2013, 07:39 PM   #3
Rewards Points: 101
Yeah, it's acrylic.
I'm not sure what you mean by mount? This is the tip that slides down over a sleeve sticking up from the roof.
Old 04-11-2013, 07:55 PM   #4
Metal Roofing
Rewards Points: 600
If they are glass skylights more than likely the seal between the two glass panels has failed. That being the case your probably going to need to replace the skylights.
AndyWRS is offline   Reply With Quote
Old 04-11-2013, 09:15 PM   #5
Rewards Points: 13,300
If they are just the cheap acrilic dome type sky lights I would not waste my time trying to polish them. Just replace with some new Velex lights.
Then there going to stay clear, and will be thermopane glass.
Moldy Skylight cbzdel General DIY Discussions 11 03-14-2013 07:14 PM
Curb-mount for skylight: 2 replace or not 2 replace? 5tudent Roofing/Siding 8 10-22-2012 09:27 PM
skylight self stick flashing advice Earl0101 Roofing/Siding 2 04-30-2011 10:55 AM
Dome skylight leaking AAK Roofing/Siding 1 10-08-2010 06:47 PM
Cracked Skylight rjordan392 Kitchen & Bath Remodeling 10 05-22-2010 03:30 PM
