Plywood Under New Shingles - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 11-12-2012, 05:19 PM   #1
Hello Everyone,
I am here because I currently have a giant hole in my ceiling. We recently (2 weeks ago) re-did the entire roof, and unfortunately did not put enough of the tar around one of the flashings. After a day of intense rain we had water dripping out of the ceiling and down the wall. We have since stopped the leak and removed all of the damaged insulation/plastic etc in the ceiling. (p.s we do not have an attic, it is just ceiling-insulation-roof no spaces) My question is, the plywood under the shingles got damaged as well, and seeing as how we just put thousands of dollars and lots of time into re-doing the roof we really do not want to have to take off the brand new shingles to change the plywood. Is there some type of fix for this? That may be a loaded question, but I am a little desperate here! I am worried about future damage. Thank you!!
jpg667 is offline   Reply With Quote
Old 11-12-2012, 05:57 PM   #2
Rewards Points: 13,748
There is no magic wand for this one. Shingles have to go.
I would love to know what you were using roof tar for on a new roof.
Old 11-12-2012, 06:07 PM   #3
ParagonEx's Avatar
Rewards Points: 150
Why was tar put around any roof penetrations on a brand new roof?
ParagonEx is offline   Reply With Quote
Old 11-12-2012, 06:12 PM   #4
It might not be tar, I do not know all the lingo for roof material, I am here because my husband thinks he knows best. Due to the water in my bedroom, he obviously doesnt. Around the pipes for the furnace I believe? We had several pipes where shingles had to be cut to fit, there wasnt enough of whatever sealer you need for that.
Old 11-12-2012, 06:24 PM   #5
That's just it, done right there would not have been any sealer needed.
Any type of "sealer" will be (as you have seen) the first place to leak.
Old 11-12-2012, 06:29 PM   #6
ParagonEx's Avatar
Rewards Points: 150
You need to install proper flashings around roof penetrations, not any type of tar if you want it not to leak.
Old 11-12-2012, 07:12 PM   #7
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
No tar, asphalt, or other sealant is to be used on the roof. That leak is the result of using it. Remove the shingles and 'sealant' around each collar and install pipe collars instead.
These are large collars here, but no different than small ones. Run shingles until they're passing the pipe, install collar and the rest of the shingles.
http://www.albertsroofing.com/Power%20Vent%20Installation.htm
tinner666 is offline   Reply With Quote
Old 11-12-2012, 07:27 PM   #8
RFN-4A-LVN
Roofmaster417's Avatar
If multiple layers are removed during a tear off the furnace flashing is usually annihilated by multiple fasteners.Its always a good idea to inspect the flashing before reuse.But for some reason roofers in my area seem to reuse all components when doing a reroof.
But as the others said no significant amount of "Tar" should be used on a new roof.
Roofmaster417 is offline   Reply With Quote
Old 11-13-2012, 01:02 AM   #9
the roofing god's Avatar
Send a message via MSN to the roofing god
Only tar I use goes at bottom of the pipe flashing,,and flashing sets into it,,can be helpful to prevent leaks that can be caused by driving rain
"If it`s worth doing,It`s worth doing right!!"
www.ADVANCEDROOFINGNEWYORK.com
the roofing god is offline   Reply With Quote
Shingles and Re-Roof Jblood Roofing/Siding 5 04-22-2011 06:43 PM
Difference between "heavier" shingles, and "wind resistant" shingles Inquiring Mind Roofing/Siding 4 02-03-2010 03:21 PM
Need new Roof Shingles larrylwill Roofing/Siding 5 12-16-2009 10:26 AM
Hardwood Subfloor: OSB vs. Plywood vs. OSB + Plywood italoblu Flooring 2 07-31-2008 12:11 PM
shingle over??? lemeno Roofing/Siding 12 12-01-2007 11:39 PM
