Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 09-03-2007, 04:08 PM   #1
FatAugie's Avatar
Question
Plywood replacment
I posted this on another forum and thought I should ask here as well.
How common is it on a standard tear off? Do you end up usually replacing a few sheets on average? I know it's on a case by case basis, but I mean in general.
How do you remove the old plywood? Saw, rip and yank? Pull the nails?
Is 1/2 sheathing rated ply the most common replacement?
Compared to tearing off and shingling, is the plywood replacement usually the slowest part of the job? Does it eat man hours?
I ask all this as I'm finishing my roof and that's what I found, the plywood replacement killed my momentum. I tore off fast, and shingled fairly fast, but the in between replacement (along with some plumbing venting corrections I had to rectify since the plywood was removed) took forever. Not to mention, with a hammer and handful of nails, it took a long time nailing them in. I have a roofing gun, but no other nailer.
When I had estimates a year or two ago, I was quoted around $53 a sheet to replace during the roofing job. Is that in the ballpark for what you guys (professionals) charge?
Tony
FatAugie is offline   Reply With Quote
Old 09-03-2007, 06:26 PM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
Plywood replacment
If the roof is done correctly the first time, there should be no replacment of the Sheathing having to be done. As for the replacement time, it is usually figured in for the "Just in Case" instances.
For example, I have a 65+ year old house that has 1x8 boards instead of Ply, and there are a couple of places the we know where there will be replacement done. Instead of replacing with Pine, it will be with 3/4" Exterior grade Ply.
Old 09-03-2007, 06:50 PM   #3
Plywood replacment
"I posted this on another forum and thought I should ask here as well.
"VERY"
Yes
YES
YES
Not really, Waiting to be paid seems to be the slowest part
yes, and it sucks too. But it does not feell as good. If ya know what I mean.
Big Bob is offline   Reply With Quote
Old 09-04-2007, 11:52 PM   #4
the roofing god's Avatar
Send a message via MSN to the roofing god
Plywood replacment
usually pop the wood up w/the same tearoff spade used to rip the roof,goes quickly,although I prefer to replace 1x w/ 1x unless it`s a ft. high as 5 1/2" plywood strips aren`t as strong
the roofing god is offline   Reply With Quote
DIY Chair mat from plywood and carpet tiles jbwaechter Flooring 3 08-20-2009 07:29 AM
Removing kitchen tile with plywood under it ediconu Flooring 4 08-26-2007 09:48 PM
Exterior plywood, not secured well enough mt232 Building & Construction 4 07-03-2007 10:34 AM
Exterior plywood mt232 Building & Construction 1 06-25-2007 09:59 AM
Backer board vs. plywood for tile underlayment allpraisebob Flooring 4 01-07-2007 08:44 PM
