-   -   Plywood replacment (http://www.diychatroom.com/f9/plywood-replacment-11234/)
FatAugie 09-03-2007 04:08 PM
Plywood replacment
I posted this on another forum and thought I should ask here as well.
How common is it on a standard tear off? Do you end up usually replacing a few sheets on average? I know it's on a case by case basis, but I mean in general.
How do you remove the old plywood? Saw, rip and yank? Pull the nails?
Is 1/2 sheathing rated ply the most common replacement?
Compared to tearing off and shingling, is the plywood replacement usually the slowest part of the job? Does it eat man hours?
I ask all this as I'm finishing my roof and that's what I found, the plywood replacement killed my momentum. I tore off fast, and shingled fairly fast, but the in between replacement (along with some plumbing venting corrections I had to rectify since the plywood was removed) took forever. Not to mention, with a hammer and handful of nails, it took a long time nailing them in. I have a roofing gun, but no other nailer.
When I had estimates a year or two ago, I was quoted around $53 a sheet to replace during the roofing job. Is that in the ballpark for what you guys (professionals) charge?
Tony
gregzoll 09-03-2007 06:26 PM
If the roof is done correctly the first time, there should be no replacment of the Sheathing having to be done. As for the replacement time, it is usually figured in for the "Just in Case" instances.
For example, I have a 65+ year old house that has 1x8 boards instead of Ply, and there are a couple of places the we know where there will be replacement done. Instead of replacing with Pine, it will be with 3/4" Exterior grade Ply.
Big Bob 09-03-2007 06:50 PM
"I posted this on another forum and thought I should ask here as well.
"VERY"
Yes
YES
YES
Not really, Waiting to be paid seems to be the slowest part:whistling2:
Does it eat man hours?:laughing:
yes, and it sucks too. But it does not feell as good. If ya know what I mean.:laughing::)
the roofing god 09-04-2007 11:52 PM
usually pop the wood up w/the same tearoff spade used to rip the roof,goes quickly,although I prefer to replace 1x w/ 1x unless it`s a ft. high as 5 1/2" plywood strips aren`t as strong
