Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing/Siding
Old 12-20-2012, 09:56 AM   #1
Plywood necessary on top of old tongue in groove?
I'm in the process of buying a 1953 cape that has very old worn asphalt shingles in need of replacing. From what I can see in the attic, there are no leaks or rot in the tongue in groove planks and it looks in fine shape. Assuming no rot, would it be advisable to still put plywood on top in order to assure that the new shingles nail securely and not potentially on a joint in the tongue in groove? I want to do this right, but like most people, have a budget. I will be doing most of the work myself with guidance from an experienced carpenter friend who suggested the ply - just looking for another opinion.
Frattman is offline   Reply With Quote
Old 12-20-2012, 10:06 AM   #2
If it's in good shape, then no there's no need for it.
I've done it when the old sheathing was not T&G and they used wood that was just filled with knots.
Old 12-20-2012, 01:29 PM   #3
Exterior Construction
Windows on Wash's Avatar
+1
T&G is better than plywood for that matter.
If its in good shape, you are good. Just make sure they use the proper length fastener.
How to repair tongue and groove that is subfloor cosmicblu Flooring 1 08-19-2011 06:12 PM
Can 2x12 tongue and groove expand & tear 15-lb tar paper? DeanL Roofing/Siding 1 05-23-2011 05:22 PM
Replacing tongue in groove with support below odonata3 Flooring 0 10-20-2010 11:40 AM
Install Cabinets directly above Tongue & Groove? caezaar Building & Construction 13 07-06-2010 10:50 PM
tongue and groove fence pickets - bad idea ? JoeT Carpentry 6 05-23-2008 12:00 PM
