-   -   plumbing vent flashing on metal roof??? (http://www.diychatroom.com/f9/plumbing-vent-flashing-metal-roof-37654/)
red86yota 02-05-2009 08:52 AM
Hello,
I'm planning on installing some standing seam metal roofing on a 2:12 pitch roof. The problem is, I'm going to have one plumbing vent penetration in the roof, and I'm not real sure what type of boot/flashing is used on metal roofs....
I have found some boots that screw down directly on the roofing surface. From the looks of it, the bracket of the boot squeezes a rubber gasket and holds it tight to the surface of the roof to seal it off. Is that the correct flasing method? I'd hate to have a leaky roof!
tinner666 02-05-2009 08:04 PM
http://rcs.si-sv2628.com/show_album_...&file=4434&s=0
Tom Struble 02-05-2009 11:11 PM
Frank whats that curlyque thing in the chimney?
tinner666 02-06-2009 09:12 PM
This pic? [img width=600 /]http://www.rooferscoffeeshop.com/images/photo_albums/30/598/Untitled-5.jpg[/img]
It's a shutter ho;d back. The house in early 1800. Dang roof was flush with the windows.
Anywhere in my albums like that, you can just click on 'Get Url' to post and ask questions, or just post the pic if you want.
Here is a link to 100 of my albums elsewhere on the web. I need to incorporate some into my websites. http://rcs.si-sv2628.com/photo_album_list.asp?u=30
I have the good, the bad, and the ugly there.
Tom Struble 02-07-2009 01:02 AM
thanks pal i added that link to my favorites:thumbsup:
OldNBroken 02-07-2009 09:31 AM
http://www.itwbuildex.com/dektite.htm
Best pipe boot I've found for SS roofs. Accept no substitutes.
jaros bros. 02-07-2009 09:52 AM
I wouldn't recommend installing a metal roof on 2/12. If you're worried about the boot for your flashing leaking, why aren't you worried about every seam leaking? I hope you don't get ice or snow.
Josh Jaros
OldNBroken 02-07-2009 10:28 AM
Josh Jaros
Depends on the system
Tom Struble 02-07-2009 10:54 AM
some standing seam systems are rated for a 2/12 but id be worried about any penetrations or valleys like on your project.From the pic ive seen your really not going to see much of the roof in back id seriously consider maybe some of the single ply systems.Not easy to fix a leak in a ss system good luck
rustyjames 02-07-2009 01:17 PM
There are some SSMRS that can be used on roofs that are as low 1/4:12 pitch. But the ribs are at least over 2" and they are mechanically seamed with concealed clips that are two piece to allow for expansion.
Tom Struble 02-07-2009 05:45 PM
those types of roofs are more a commercial product way over scale for a small residential job it would look out of place
rustyjames 02-07-2009 07:29 PM
Not necessarily, on shallow pitches, in many cases, you can't really see the roof. And in many other cases (certain neighborhoods) a metal roof would look out of place anyway.
jaros bros. 02-07-2009 09:18 PM
I've seen ice and buildup rip sheets and flashing right off of standing seam on low pitch roofs. As long as the OP isn't in a cold weather area it would probably be okay.
red86yota 02-09-2009 12:34 PM
thanks for all the replies...
i wasn't aware of the potential problems with SS roofing....the spec sheet for the system i was looking at said it was good for 2:12 pitch. i'll contact the manufacturer and explain my roof to see what is recommended. i live in Michigan, so there will definitely be snow and ice.
for what it's worth, here are a couple pics of the roof:
http://lh5.ggpht.com/_NdO8bpyJi6Y/SR...2020-33-53.jpg
http://lh3.ggpht.com/_NdO8bpyJi6Y/SX...0/P1000342.JPG
the roof is pretty hard to see because of the low slope. you can only see a tiny portion of the roof while standing in our yard. our next door neighbors will be able to see it for sure.
http://lh3.ggpht.com/_NdO8bpyJi6Y/SX...0/P1000345.JPG
red86yota 02-09-2009 12:40 PM
oh yeah, forgot to mention some more specifics:
the front of the roof is 8:12 pitch with architectural shingles. not planning on replacing this.
the roof won't be vented...i'm going to have closed cell foam sprayed to entire roof deck from below. R50 insulation.
the entire new roof is covered in Grace water & ice shield. I'm going to take a couple of courses of shingles off the top of the old roof and lap a piece of Grace over the main ridge.
