Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 01-10-2011, 07:09 PM   #1
Please help - condensation or leak?
Hi,
I have what I think is called a cathedral ceiling, in the second bedroom of my property, it is a pitched ceiling which follows the line of the roof and appears to have very little in between the interior ceiling and the roof. The inside is "plastered" with artex, which has been painted. The ceiling is damp to touch and sometimes has droplets of water which run down. When I first saw the problem, I assumed it was a leak and called a roofing man (he said that the roof was in generally good condition but quoted to extend some lead flashing in the hope of remedying the problem). But having searched the net I am now confused as some websites suggest the problem may be condensation.
Is there any sure way to tell if the problem is a leak or condensation?
What would be the remedy if the problem is condensation?
Please help!!
Becca
becca is offline   Reply With Quote
Old 01-10-2011, 07:23 PM   #2
Super Moderator
This sounds like condensation to me---It is common with cathedral ceilings--
Warm moist air rises and hits the cooler ceiling---bingo--water drops.
Your best bet is to get the air moving--if you have a ceiling fan turn it on in the reverse setting so that it is blowing UP towards the ceiling----Mike---
Tags
ceiling, condensation, damp, leak, roof
condensation leak with metal roof on cathedral ceiling in Canada Serialrenovator Roofing 10 02-02-2010 01:18 AM
Moisture on windows baum Building & Construction 56 12-22-2009 06:39 PM
Carrier Condensation Leak joehomeowner HVAC 4 11-21-2009 10:17 AM
Shower leak (what else) Old home, new owner... Rubbertree Plumbing 8 09-25-2009 02:26 PM
A Leak and Why No Condensation from AC? sneaky_pete HVAC 3 08-19-2008 06:55 PM
