Please Advise - Step Flashing Installation - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-14-2014, 08:33 PM   #1
Please advise - step flashing installation
We are in the process of getting a house built through a national builder. An independent inspector pointed out that our roof step flashing was installed over the WRB/house wrap, which according to the inspector is a huge issue (reverse shingling?) that will lead to leaks as soon as the tape holding the WRB in place gives out. Our builder and the roofing subcontractor claim that this installation is completely acceptable and simply one of many ways of flashing a roof and refuse to change the installation. Who is right? How serious is this and how likely is it to lead to problems down the road?
vaczyz is offline   Reply With Quote
Old 04-14-2014, 08:41 PM   #2
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
It's incorrect. Builders and siders have NO clue how to waterproof a window, wall, or door, and plenty of water will see the WRB every time it rains. It will eventually work it's way behind the flashing and leak. Often, just after the builder's warranty expires.
The Inspector is correct. Refuse to pay/purchase until remedied.
tinner666 is offline   Reply With Quote
The Following 3 Users Say Thank You to tinner666 For This Useful Post:
rossfingal (04-15-2014), vaczyz (04-16-2014), Windows on Wash (04-15-2014)
Old 04-14-2014, 08:43 PM   #3
Rewards Points: 536
Not sure what you mean specifically, bt if you check out the instructions for flashing say a skylight, it is the wrb (graces or the like) that goes on FIRST followed by an interweave of shingles and flashing. Ron
ront02769 is offline   Reply With Quote
Old 04-14-2014, 11:57 PM   #4
Registered User
Rewards Points: 526
And the roofer is paid by the builder.... hmm. Did you check on-line with the asphalt shingle manufacturer or read the paper wrapping for step-flash details?
The WRB requires lapping over itself to direct water outward; " R703.2 Water-resistive barrier.
One layer of No. 15 asphalt felt, free from holes and breaks, complying with ASTM D 226 for Type 1 felt or other approved water-resistive barrier shall be applied over studs or sheathing of all exterior walls. Such felt or material shall be applied horizontally, with the upper layer lapped over the lower layer not less than 2 inches (51 mm). Where joints occur, felt shall be lapped not less than 6 inches (152 mm). The felt or other approved material shall be continuous to the top of walls and terminated at penetrations and building appendages in a manner to meet the requirements of the exterior wall envelope as described in Section R703.1. " From; http://publicecodes.cyberregs.com/ic...2_7_par034.htm
And basic Building Science requires it; http://www.buildingscience.com/docum...rainage-planes
Otherwise, you have water problems; http://www.google.com/url?sa=t&rct=j...,d.aWc&cad=rja
Even metal/sticky flashing require "shingle" method;
"Approved corrosion-resistant flashing shall be applied shingle-fashion in a manner to prevent entry of water into the wall cavity or penetration of water to the building structural framing components. Self-adhered membranes used as flashing shall comply with AAMA 711. The flashing shall extend to the surface of the exterior wall finish. Approved corrosion-resistant flashings shall be installed at all of the following locations: " read the rest at; http://publicecodes.cyberregs.com/ic...2_7_par066.htm
Side-walls; http://publicecodes.cyberregs.com/ic...2_9_par030.htm
Where are you, State? What type/brand of siding?
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
vaczyz (04-16-2014)
Old 04-15-2014, 06:13 AM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,554
We talking about housewrap or Ice/Water?
Old 04-15-2014, 07:21 AM   #6
Rewards Points: 656
Is it a very simple fix if its just over the housewrap, I cant imagine anyone refusing to fix it at this point.
If they want to let something like this go, I would have your independent inspector over more regularly...
PatChap is offline   Reply With Quote
The Following 2 Users Say Thank You to PatChap For This Useful Post:
vaczyz (04-17-2014), Windows on Wash (04-15-2014)
Old 04-15-2014, 04:30 PM   #7
Rewards Points: 536
Gary
Bad day for me, must be missing something again. Everyone's response is dealing with flashing over doors and windows, house wrap, and the like. But I thought that the OP was asking about step flashing STEP-FLASHING on the ROOF which I am assuming is in a valley or along the edge of a dormer or the like. And in those cases the wrb goes on first with the shingles and step flashing interwoven over the top.
Ron
Old 04-15-2014, 04:48 PM   #8
kwikfishron's Avatar
Ron
I thought OP was talking about the wall side of the step flashing being over the wrb and then taped. Is so then that's a bad detail that will fail...Especially if the siding is vinyl.
kwikfishron is online now   Reply With Quote
Old 04-15-2014, 04:50 PM   #9
Rewards Points: 656
Ron
Along sidewalls the step flashing is installed and then the housewrap(on the wall) is install overtop of that. This brings any accumulated moisture to the outside of the assembly...
roofermann (04-16-2014), vaczyz (04-17-2014)
Old 04-15-2014, 11:21 PM   #10
Registered User
Rewards Points: 526
" roof step flashing was installed over the WRB/house wrap"-------- house wrap would not be installed on roofs, only walls. Water Resistive Barrier, per code; "WATER-RESISTIVE BARRIER. A material behind an exterior wall covering that is intended to resist liquid water that has penetrated behind the exterior covering from further intruding into the exterior wall assembly. "
Perhaps if said installed after the house wrap...... it may be understood better for some...this link shows you have to apply sticky flashing and metal flashing in "shingle fashion" on step-flashing at a side wall (as stated earlier); http://publicecodes.cyberregs.com/ic...2_7_par066.htm
Gary
vaczyz (04-17-2014)
Old 04-16-2014, 06:40 AM   #11
Thank you all for these great and informative responses.
Just a few clarifications. I was asking about the wall side of roof step flashing being installed over WRB and then taped in place. Our siding will be vinyl by KP products. We are located in SC. I am attaching a picture of what this looks like. They seemed to have followed this pattern elsewhere on the house where flashing and WRB meet (except windows).
Although it seems like it would be easy to fix at this stage, the builder refuses to fix as "this is how they have always done it".
Old 04-16-2014, 09:55 AM   #12
Pro Slate Roofer
tinner666's Avatar
"this is how they have always done it". Is no excuse for doing it wrong. Sounds like they should switch plans and attempt to do something correctly for once.
The Following User Says Thank You to tinner666 For This Useful Post:
vaczyz (04-17-2014)
Old 04-16-2014, 09:57 AM   #13
Pro Slate Roofer
tinner666's Avatar
Not too swift on window flashing either. http://www.albertsroofing.com/Window%20Flashing.htm
vaczyz (04-17-2014)
Old 04-16-2014, 12:54 PM   #14
Registered User
Rewards Points: 526
You are under the IBC codes, not IRC; http://www.reedconstructiondata.com/...outh-carolina/
Much more difficult to research and prove the sticky tape problem.
Speaking of problems; http://www.consumeraffairs.com/housing/ryan.html
Nothing definite about sticky use; http://publicecodes.cyberregs.com/ic..._14_par044.htm
Did you check the shingle maker directions with flashing to side-wall; http://publicecodes.cyberregs.com/ic..._15_par070.htm
Tapes are not long-term equal to lapping HW; Tyvek behind vinyl siding
Still researching Tyvek (Ryan brand) flashing application instructions, though you may have to live with existing in the end, IMO.
Gary
vaczyz (04-17-2014)
Old 04-16-2014, 01:44 PM   #15
Registered User
Rewards Points: 526
IF (you would need to verify) Ryan is using Tyvek brand, the instructions are pretty straightforward using step flashing; pp. 5- tape to air-seal, Step #5.
And step-flashing lapped with Tyvek only- not tape on page #6 under "Terminations"; http://www.google.com/url?sa=t&rct=j...pg_Gog&cad=rja
Your windows are not correct, hard to see from pictures- though the jamb tapes are wrong (over the head tape);
Window after Tyvek; http://www.google.com/url?sa=t&rct=j...,d.aWc&cad=rja
Window before Tyvek; http://www.google.com/url?sa=t&rct=j...64764171,d.aWc
Gary
PS. Welcome to the forums!
vaczyz (04-17-2014)
Repair or Replace Roof-to-Wall flashing Learn as i go Roofing/Siding 9 09-25-2014 11:53 AM
Roof patch job ok or not? daluu Roofing/Siding 8 11-07-2012 08:56 AM
Re-roofing: flashing question prb_nearnorth Roofing/Siding 9 04-30-2012 11:42 PM
Vinyl siding corner posts and flashing on dormers rhastler Building & Construction 7 06-05-2009 10:08 PM
Do architectural shingles really work with step flashing? Malcolm Roofing/Siding 7 05-02-2008 10:31 PM
