Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 11-29-2011, 12:33 PM   #1
plastic tar strip
do you remove this so shingles stick better to each other on the roof
jpapworth is offline   Reply With Quote
The Following User Says Thank You to jpapworth For This Useful Post:
builder555 (11-30-2011)
Old 11-29-2011, 12:51 PM   #2
Pro Slate Roofer
tinner666's Avatar
plastic tar strip
No you don't. THat's why some manufacturers even went so far as to print "DO NOT REMOVE" on theirs. It's in the nail zone which also gives the nail additional holding power.
Frank
tinner666 is offline   Reply With Quote
The Following User Says Thank You to tinner666 For This Useful Post:
Windows on Wash (11-29-2011)
Old 11-29-2011, 01:07 PM   #3
Exterior Construction
Windows on Wash's Avatar
plastic tar strip
+1
That bitumen strip is what beds the shingle into the course below and heals the nail location.
Old 11-29-2011, 02:49 PM   #4
MJW
plastic tar strip
It prevents the shingles from sticking together in the bundle. With most newer shingles, the plastic strip is on the top of the shingle, some even on the front of the shingle. Just depends on how they are packaged.
MJW is offline   Reply With Quote
The Following 2 Users Say Thank You to MJW For This Useful Post:
builder555 (11-30-2011), Slyfox (11-30-2011)
Old 11-30-2011, 05:20 AM   #5
plastic tar strip
Hello, I'm trying to figure out why I have shingles falling off in a one year old home. I first noticed this last summer. Had the roof looked at by a professional, and repaired for another issue. It was checked at that time. Anyway, one or two shingles were on my front lawn at that time.. had fallen from that area above. Then after our first snow this year, a few weeks ago, I've seen 3, all at different times on the lawn in the same area. I am wondering why this happened. Never had this happen on any home I've lived in. Thank you!
Also, sorry I tried to post this in the posting section, but couldn't.. So I am "posting" it as a reply. Thanks again.
builder555 is offline   Reply With Quote
Old 11-30-2011, 05:23 AM   #6
plastic tar strip
I just revised it, and you had already posted it, thank you..
Old 11-30-2011, 07:48 AM   #7
plastic tar strip
Look at the shingles that blew off for clues. My guess is they were nailed too high, and probably with air guns set wrong which causes the nail to blow through the surface of the shingle.
Sometimes the sealant fails too, but it's usually the nailing.
jmiller is offline   Reply With Quote
The Following User Says Thank You to jmiller For This Useful Post:
Slyfox (11-30-2011)
Bad or failed heat strip. Any ideas why. 50juan HVAC 25 12-04-2011 05:04 PM
Goodman GPH1336H21AA heat strip connection jrajra HVAC 2 09-02-2010 05:52 PM
Plastic roof for enclosed attachment helen33 Roofing 0 08-31-2010 09:48 PM
Chrome paint on plastic Thurman Painting 3 08-24-2010 01:17 PM
Plastic instead of metal... hvaclover Electrical 11 11-13-2008 10:07 AM
