Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 09-27-2011, 02:00 AM   #1
Placing shingles on wet felt
My contractor removed all the existing roof and laid felt. That night, it rained buckets. The next day, they came and started laying shingles like nothing happened. Is it a problem or will the felt dry out? It seems to me that the wet felt between the subroof and the shingles will stay wet and will eventually mold.
rwunderground is offline   Reply With Quote
Old 09-27-2011, 05:15 AM   #2
Exterior Construction
Windows on Wash's Avatar
It should dry out and should not have absorbed that much moisture to begin with.
I would always prefer to let the roof dry for a day but then again I would always prefer to work in 65 degree weather will good sunshine but that isn't happening either.
This is why I prefer synthetic but felt has been around for ages and people have gone over top of it the day after a rainstorm.
Old 09-28-2011, 10:32 PM   #3
Not to worry! I have never had a problem with moisture getting trapped between felt and shingles. Also, what happens when the shingles and felt paper are sitting at the lumber, manufacturer, or roofing yard and they get stacked and re-stacked when it rains? They get wet! The sun dries them out.
Sabre_Fan is offline   Reply With Quote
Old 09-28-2011, 10:33 PM   #4
The beauty of one day roof installs.
OhioHomeDoctor is offline   Reply With Quote
Old 09-28-2011, 11:21 PM   #5
RFN-4A-LVN
Roofmaster417's Avatar
Call me silly but.,.,I make a rule of NOT removing more than can be put back.., I have always slept well with that idea.
When the rains come alot of homeowners fret and worry and start posting inquiries about felt getting wet.,then if it leaks insulation concerns and rightfully so.
So why even set yourself up like that.It is a good indication trust is a factor when these post's are made.
Maybe your experience and common sense is put in the spotlight so why even go there.
That is my opinion though.
Roofmaster417 is offline   Reply With Quote
Old 09-29-2011, 01:38 PM   #6
firehawkmph's Avatar
Good way to do it RM. I have noticed in my area that just about every roof going on now the company shows up with about 8-12 guys and tears it off and puts the new one on all in one day. I don't hardly see any jobs going with only a few roofers working for a few days.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 09-29-2011, 04:18 PM   #7
MJW
Mike Hawkins
That's because no one is a true roofer anymore. It's just cheap labor. Is it worth it to have it done in one day when most of the people working on your house are considered low skilled?
Besides, every person that was in any construction trade that is now laid off or out of work is now a "roofer" doing sub work.
Most people are hiring a sales pitch.
MJW is offline   Reply With Quote
The Following User Says Thank You to MJW For This Useful Post:
seeyou (09-29-2011)
Old 09-29-2011, 06:24 PM   #8
RFN-4A-LVN
MJW you sure have been a little cranky lately.,.,
But I understand your point.
It is like an assembly line down at the BBQ manufacturing plant.
I don't know about you but when I buy anything that requires assembly anymore I am always missing some bolts,nuts or washers or a handle here or hinge there..
Maybe some of the pride has been removed to satisfy the demand for production.I was not saying that it is imperative to have a job completed by 20 people in 1 day.
I was merely commenting that some caution should be used when tearing a roof off when a threat of rain is forecasted.
Hell.,we cannot always complete what is open but tarps are a good thing to use to help keep the felt dry.IMO of course.
Old 09-29-2011, 06:33 PM   #9
MJW
Didn't quote you or refer to you in my post RM. Sorry if you took it that way.
I agree with only tearing off what you can put down, especially with any chance of rain.
To the OP, if it rained buckets on a roof only dried in with felt and had no leaks....they did a pretty good job, IMO.
seeyou (09-29-2011)
Old 09-29-2011, 06:36 PM   #10
Shut in w/o Home
seeyou's Avatar
I've only ever done about 5 roofs that could be done in a day.
New often construction roofs stand under felt for a long time before they get roofed.
To the OP: We normally let the sun hit the felt before we start shingling, but it shouldn't be a problem.
seeyou is offline   Reply With Quote
Old 09-29-2011, 06:38 PM   #11
RFN-4A-LVN
MJW.,.,No worries friend.,.,I just noticed you were not your usual buy all the cookies from the girl scouts or clean your neighbors gutters for free on their 12/12 3 story walkout basement jolly self.,Hahahahahaha.,.,.,
Old 09-29-2011, 06:40 PM   #12
Shut in w/o Home
seeyou's Avatar
We dry-in so it doesn't leak (well almost never). It's not that hard to accomplish. But we do tarp the next section we'll be working on in the winter for over night in case it frosts hard or snows. Take the tarp off and you've got a clean roof.
edit: Damnit RM, you've got me yelling now.
The Following User Says Thank You to seeyou For This Useful Post:
Roofmaster417 (09-29-2011)
Old 09-30-2011, 07:42 PM   #13
We have the same policy as Roofmaster. Our crews do not rip what they cannot shingle that day. Anyone experience any wrinkled felt after its gotten wet?
Roofster is offline   Reply With Quote
Old 09-30-2011, 08:09 PM   #14
ParagonEx's Avatar
We do our best to only tear off what we can cover in the same day but things do happen.
For example, yesterday there was no rain in the forecast. Started a roof and had it torn off and half felted and it starting pouring. Got the rest felted and water tight, stormed all night, roofed it today.
www.paragonexteriors.com
ParagonEx is offline   Reply With Quote
Old 09-30-2011, 08:37 PM   #15
MJW
That's pretty bad luck. Hope it worked out for you with no leaks.
Had that happen once or twice myself. Have you tried the weather apps for the phones?
Re-roofing Architectural Shingles over Architectural Shingles NoDIY4Me Roofing 9 09-04-2011 10:29 AM
Adhesive window flashing and 30# felt Numb Building & Construction 4 05-24-2011 12:04 AM
Fastners for felt, other questions. J S Machine Roofing 9 03-09-2011 10:38 AM
Help! -- what is causing these shingles to fail? imaginator Roofing 1 09-18-2010 07:29 PM
IKO Shingles - beware mtugrad1985 Roofing 7 02-10-2009 04:42 PM
