Pitch Roof On Job Site Trailer - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 12-28-2010, 09:19 PM   #1
pitch roof on job site trailer
I just purchased a used 8 x 24 job site trailer. This looks different than a conventional trailer. It is higher, has a roll up door the width of the trailer in back, office, two cadet heaters, air conditioner, wired with 220, inside walls are unfinished plywood. My question is, I am turning this into a temporary art studio and will use it as a craft room later. To make it last longer, I thought about putting a low pitch roof to have rain (live in northwest) drain off. I read one report that trailers can't support weight of roof. Would like any input. Thanks
islandartist is offline   Reply With Quote
Old 12-29-2010, 08:00 AM   #2
Residential Roofer
Slyfox's Avatar
Rather then change it's structure to create the slope use an iso board insulation system with a single ply material over that.
If you contact your local roofing supplier and tell them what you need/want they can go to the manufacturer for you and have the spec's drawn up.
God Family Country Work Play
Facebook <> Twitter
Slyfox Exteriors Co.
Slyfox is offline   Reply With Quote
Adjusting LVL beam to pitch of roof tobicol7 Building & Construction 1 06-05-2010 01:22 AM
2.25 pitch roof...15 or 30 lb felt? my5sons Roofing/Siding 13 12-08-2009 05:08 AM
shingle 1 pitch roof Toolmaster Building & Construction 3 04-01-2009 06:43 PM
How to tie low pitch roof into sides of house OR build up? jcrack_corn Building & Construction 9 06-22-2008 03:38 PM
Building Roof over Roof, changing pitch Thomas O Roofing/Siding 7 03-05-2008 09:51 PM
