Pitch - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-15-2009, 08:54 PM   #1
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 182
Pitch
How steep does a roof have to be to use shingles. An addition on my house has roll roofing and I was wondering if it could be shingled.
rusty baker is online now   Reply With Quote
Old 06-15-2009, 08:59 PM   #2
The shingle manufacturers vary between a 2 1/2" per 12" and a 3/12 slope.
If shingling even at these miinimum slopes, it is recommended to install a product similar to Grace Ice and Water Shield under them in lieu of standard felt paper.
How flat of a surface are you talking about?
You determine that by the amount of rise, expressed in inches typically versus the amount of run, also in inches per foot. The run is the horizontal distance from the one end to the other, so if you calculated from the gutter eave edge go one foot and see how many inches up the roof slope transitioned.
Ed
Ed the Roofer is offline   Reply With Quote
Old 06-16-2009, 08:26 AM   #3
Residential Roofer
Slyfox's Avatar
Take a 12" long board, 2x, 1x, etc.,
place it on the roof with one end pointing to the gutter and the other end pointing to the upper end, than leaving the stick pointing toward the upper end firmly on the roof lift the end toward the gutter up until it's level,
measure from the roof to the bottom of the board and that's your pitch.
If you take the time to make sure it's as level as possible your read will be fairly accurate, usually with in 1/4".
Like Ed said, Certainteed 'I believe' has spec's for a 2 1/2/12 pitch but most stop at a 3/12 pitch being the lowest for allowing shingles.
God Family Country Work Play
Facebook <> Twitter
Slyfox Exteriors Co.
Slyfox is offline   Reply With Quote
Old 06-16-2009, 11:12 AM   #4
Rewards Points: 182
Thanks to both of you. When the tornado warnings stop, I'll measure it.
best for low pitch roofs tomseeley Roofing/Siding 3 06-09-2009 09:54 AM
Attic trusses and proper roof pitch Rob63 Carpentry 1 07-28-2008 03:38 AM
Building Roof over Roof, changing pitch Thomas O Roofing/Siding 7 03-05-2008 09:51 PM
lowest pitch for shingles redrider Roofing/Siding 4 03-02-2008 10:38 PM
Changing Pitch over roof. tying into house rafters? EnlightMent Roofing/Siding 3 03-27-2007 12:16 AM
