Pipe Boot Recommendation - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-17-2013, 10:39 AM   #1
Pipe boot recommendation
What brand(s) of pipe boots would you recommend...and why? Thanks, in advance, for your assistance.
njniii is offline   Reply With Quote
Old 10-17-2013, 11:09 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,784
The properly installed kind.
No...but in all seriousness, is this for a new roof application?
I like doubled up exterior collars or something like a PermaBoot.
Old 10-24-2013, 10:59 PM   #3
Roofmaster
Rewards Points: 2,172
What type of roof are we talking about here?
Old 10-24-2013, 11:05 PM   #4
It is a steep (5/12) shingle roof.
Old 10-25-2013, 07:31 AM   #5
747
registered
747's Avatar
Rewards Points: 534
Your options are rubber or metal. The metal ones are the best. But more expensive. Rubber will work if properly installed. Sealed (caulked) on top and on the side seam. Also when my roof was done. I had them run ice and water sheild for addition protection.
747 is offline   Reply With Quote
The Following User Says Thank You to 747 For This Useful Post:
njniii (10-25-2013)
Cutting and gluing PVC pipe to washer steve3847 Plumbing 8 10-03-2012 09:00 AM
Whatís the best way to remove pipe from T Jaylyn Plumbing 2 02-03-2011 02:05 AM
Backpitched Cast Iron Pipe in Basement....uggh.. apunaha23 Plumbing 5 02-02-2011 02:42 AM
Lead Drain Pipe Project Turbo98 Plumbing 33 01-30-2011 12:27 PM
First Furnace Install - Need Some Help Getting Started hartkem HVAC 17 10-11-2008 12:55 PM
