Picking A Qualified Roofer For ShingleVentII - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-07-2010, 01:43 PM   #1
picking a qualified roofer for ShingleVentII
Just a joe home owner here. How can I select a local roofer (southern Delaware) that is competent in installing ShingleVent II ridgevent system after removing existing one from a 3 yr old house. Too many fly by nights in my area. What do I ask? Thanks for any help from a newbie.
mackazon is offline   Reply With Quote
Old 05-07-2010, 01:51 PM   #2
Download the specifications sheet for installation instructions and also several of the AirVent.com brochures and ask them questions to see if they are familiar with the Air Vents methods and Principle Of Attic Ventilation.
It really is not brain surgery, but they do need to be installed as close to the specifications as possible.
Anyone who is conscientious could read them and do the install, but far too many roofers and contractors have never read one single line of anything before, because they already know it all.
Ed
Ed the Roofer is offline   Reply With Quote
The Following 2 Users Say Thank You to Ed the Roofer For This Useful Post:
Gary in WA (05-07-2010), mackazon (05-07-2010)
Old 05-08-2010, 04:30 PM   #3
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
Ed
I knew you were gonna say that.......
seeyou is offline   Reply With Quote
Old 05-08-2010, 06:04 PM   #4
Residential Roofer
Slyfox's Avatar
The first thing to ask them is why did the existing 3 year old ridge vent fail.
Are you sure your existing ridge vent did fail?
Is it possible the ridge vent is performing properly but the Intake or Air flow is the problem?
God Family Country Work Play
Facebook <> Twitter
Slyfox Exteriors Co.
Slyfox is offline   Reply With Quote
The Following User Says Thank You to Slyfox For This Useful Post:
mackazon (05-11-2010)
Old 05-08-2010, 06:08 PM   #5
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
I wonder if maybe it leaked or let snow in. I've had to replace some that didn't keep fine snow out too well.
Old 05-08-2010, 07:06 PM   #6
Residential Roofer
Slyfox's Avatar
That's why i brought it up, I have done several inspections and found the existing problems are repairable as well rather than needing to be completely replaced.
Installing ridge vent is like changing a tire, not a hole lot of rocket science knowledge going on there and more often than not "in my experiences" it's a simple matter of incorrect fastening of the product 'vent itself and cap covering it' that causes the issues.
Facebook <> Twitter
Old 05-08-2010, 07:31 PM   #7
Like Sly said, the proper length of nails may not have been used, creating a gap in the compression seal down to the shingle material surface.
Photos courtesy of Gerry of GAK Roofing, taken during one of his inspections.
I just had to get a copy of these for my folder.
This case is extreme, but also very typical.
Ed
picking a qualified roofer for ShingleVentII-ridge-overview-100_2086-resized.jpg   picking a qualified roofer for ShingleVentII-close-up-nail-pops-through-shinge-caps-100_2088-resized.jpg   picking a qualified roofer for ShingleVentII-lengthier-look-ridge-cap-nail-pops-100_2089-resized.jpg
The Following User Says Thank You to Ed the Roofer For This Useful Post:
Old 05-08-2010, 08:30 PM   #8
Residential Roofer
Slyfox's Avatar
Ed
LOL, that's pretty bad Ed, I'm not sure I have ever seen one that bad and I do a lot of repairs & inspections.
Are my eyes deceiving me or is the back pan on that chimney over top the shingles?
Facebook <> Twitter
Old 05-09-2010, 05:12 AM   #9
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
Looks like they wrapped the base of the chase with a 2x4. We use a detail similar to that which allows the base flashing to be replaced when re-roofing without disturbing the peel & stick stone.
Old 05-10-2010, 02:07 PM   #10
Sly, those are photos from an inspection that Gerry, (GAK), did not too long ago.
My eyes see the same thing as yours do.
Ed
Old 05-11-2010, 06:49 AM   #11
yes. It was totally flattened when bundles of shingles were thrown on top of it. You can light an inscence stick or candle up there and no smoke at all goes upwards. It hits 145 up there in summer.
Old 05-11-2010, 08:55 AM   #12
Rewards Points: 12
Good photos Ed (Gary) of what not to do. That's what happens when you pull off the ridge shingles and reinstall same ones over vent...you get nail holes which could leak. You can't see it from the ground as much, so some take short-cuts and get away with it unless homeowner will get up and inspect. Should either buy new ridge shingles or use the 3 tabs.
I'm curious, what manufacturer of ridge vent is under there? I like the low profile and might have that installed if the HOA denies shinglevent II.
igneous1 is offline   Reply With Quote
Old 05-11-2010, 03:36 PM   #13
I have never seen it like that with the ridgecap. Interesting.
And - My eyes are younger than your guys and I see the same thing you do about the chimney flashing. Hmmm.
BamBamm5144 is offline   Reply With Quote
Roofer refuses to use 30# felt Dodah Roofing/Siding 12 06-23-2009 11:17 AM
Tips on How to find a roofer in Oregon Stormy873 Roofing/Siding 6 10-09-2006 09:39 AM
Would this be a good deal for a roofer or is it a dumb thought Doug Crf Roofing/Siding 5 05-09-2006 10:44 PM
