Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 07-04-2007, 11:42 PM   #1
Pergola question
I all, I'm pretty new to the DIY game, so this may be a silly question.
I've just about finished putting up and 8m x 4 M Pergola (the kind that's right up to the house roof). I've got mostly tin on with 2 sheets of plastic. Now I've still got flashing to do, but I've been told to put some rubber type filler under the plastic before I lock it down, also under the flashing. The problem I have is I understood I can drill (with the roof screws) straight through the tin/plastic and into the rubber, but the screws just wind up the rubber.
Can someone explain why I need the rubber and a technique for getting it in place. Eg. glue it in place with IronNail then screw in?
Joseph
josephemm is offline   Reply With Quote
Old 07-18-2007, 10:46 AM   #2
Pergola question
If you could post a picture, it would help with my understanding of the flashing detail.
The rubber seals out the water from going down the screw shaft. It only has to be a little snug, You might try some soap on the washer to give it more slip and less grab.
Ron
More On This Topic
How to Repair Roof Flashing
How to Repair Roof Flashing by eHow Home & Garden Editor
Whenever it's practical to replace damaged roof flashing, do so. In an emergency or when replacement is too difficult or expensive, use a patch and inspect it annually. Typically, you can use this method for step flashing, which interlaces with shingles... Read More »
Inspect your roof flashing and, if necessary, re-seal it before the extreme winter elements hit. Learn more in this free educational video series. Read More »
Learn how to install roof valley flashing in this free roofing instruction video. Read More »
Some Holga cameras now have flashes. Learn about different camera models from a professional photographer in this free camera video. Read More »
At some point, you may need to replace the flashing around the vents in your roof. If you aren't afraid of heights, you can replace the flashing yourself. Make sure you don't fall. Also, wear gloves to protect your hands from the sharp edges of the vent... Read More »
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
General easy drywall question bigboyjoel Building & Construction 3 05-27-2007 09:52 AM
Sidewalk Meets Concrete Truck Question craigNeasttx Building & Construction 5 03-25-2005 12:40 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
