Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 03-18-2012, 09:43 AM   #1
Exclamation
pergola
Is good idea to use beam 4×10 on a pergola of 16×16?
frost is offline   Reply With Quote
Old 03-18-2012, 09:45 AM   #2
Civil Engineer
pergola
What exactly is it you want to do with the 4x10 beam?
The Following 2 Users Say Thank You to Daniel Holzman For This Useful Post:
DangerMouse (03-18-2012), frost (03-18-2012)
Old 03-18-2012, 09:54 AM   #3
pergola
Well i have already set up 6 post of 4×4 but i don't know about the beam size, i just want to do the top of the pergola
Old 03-18-2012, 10:04 AM   #4
pergola
I just want to do the top the pergola
Old 03-18-2012, 10:07 AM   #5
Civil Engineer
pergola
This feels like 20 questions. Maybe you can post a sketch of what you are trying to build. How far apart are the posts. Where are you located? Are you planning to support the roof with the beams? What are your local code requirements. if any? Are you planning to design for wind load, or is it OK if the roof flies away during a major storm? Right now I have no idea exactly what you are building, and there is no context for the beam question.
Old 03-18-2012, 12:02 PM   #6
Doing This Way Too Long
pergola
16x16 with six posts would mean 8' on center. 4x10 is overkill but your local lumber yard would be able to tell you what the minimum requirement is.
And pergola's don't have roofs that will blow away in the wind. Other than that I agree.
This is more a framing question than a roofing question
OldNBroken is offline   Reply With Quote
Pergola Beam Question jallred1 Building & Construction 7 07-08-2012 06:37 PM
Pergola over existing deck cpfullback Building & Construction 0 08-04-2011 12:36 PM
Deck and Pergola getzjd Project Showcase 17 07-02-2011 10:36 AM
Pergola on Elevated Deck stubits Building & Construction 0 06-19-2010 09:48 AM
Pergola - paint or stain - then maintenance woodsglen Painting 2 07-15-2008 09:30 PM
