Peel And Stick Single Membrane Rolled Roofing - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-14-2011, 04:11 PM   #1
Peel and Stick Single Membrane Rolled Roofing
Saw a roll of this in HomeDepot about 2 years ago, in the Langley BC store; failed to get the product identifier/proper name....
Want to do inexpensive reroofing application on a small shed housing my water intake.
Particularly looking a light green (colored)...
Current roof has 40 yr old rotting asphalt shingles on interior OSB, which was laid upon 1 layer of 1x4 lathing with 6" spacing...
Roof has 3/4 slope, and the top is centered on the shortside of the insulated rectangular bldg. which 8' wide by 12' long.
Buiding location is in South Surrey, BC Canada..a wet but temperate climate, with snow in the winter months.
Magillicutty is offline   Reply With Quote
Old 07-14-2011, 05:09 PM   #2
Grumpy's Avatar
Rewards Points: 540
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
It was probably GAF liberty if it was at home depot. It is in a classification of "Self Adhering Modified Bitumen". Good luck, and stay away from the torch.
-Grumpy http://www.illinoisroofinspections.com
The information found in this post is not to be considered legal advice. The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
Old 07-14-2011, 09:46 PM   #3
RFN-4A-LVN
Roofmaster417's Avatar
Liberty or Mule Hide are the products I would recommend for a Diy'r or an experienced installer.
It is a much cleaner product to work with.I highly recommend the base sheet that goes with the product.Its about the same price as the cap sheet but well worth it.
Use simplex capped nails for the base installation.
Roofmaster417 is offline   Reply With Quote
Peel and Stick Veneer and Contact Cement GreggG Kitchen & Bath Remodeling 6 02-23-2015 05:30 PM
Removing peel and stick tile adhesive in preparation for tile stubborn1 Flooring 3 01-09-2011 01:34 PM
Do I fill the cracks when I am putting peel and stick tiles? bherdman Flooring 5 04-05-2010 04:01 PM
Re-Roofing: Okay to Re-Use Peel n Stick? GrillMouster Roofing/Siding 8 12-06-2009 01:55 PM
Peel and stick matching melkisadek Flooring 6 01-16-2008 07:52 AM
