Patio Roof Question? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-10-2009, 11:59 PM   #1
Lightbulb
My patio roof needs to be replaced, Does anyone know about torch roofing>
homelocation2 is offline   Reply With Quote
Old 08-11-2009, 08:34 AM   #2
Rewards Points: 342
Hi homelocation 2. Welcome to the forum. Look in the index for ROOFING and post your question there. You'll have a much better chance of getting an answer.
gma2rjc is offline   Reply With Quote
Old 08-11-2009, 08:49 AM   #3
What would you like to know about it?
johnk is offline   Reply With Quote
Old 08-11-2009, 10:31 AM   #4
Residential Roofer
Slyfox's Avatar
Torch down itself has a few different types of application,
plus it's just one of a few dozen systems that can be installed on flat/low sloped roofs.
Many roofers 'myself included' steer away from torch down systems for the simple reason of the added risk of dealing with the flames around lumber, insulation, etc.
Plus many single ply systems are less labor intense and still give the same life span expectancy.
There are also self adhered systems that go down with out the use of a torch but give the same end result in both looks and life span.
I have installed thousands of squares of torch down, but less than 100 squares of those where on residential.
There's far to many systems available for residential projects to worry about dealing with the extra risk of a torch down system.
God Family Country Work Play
Facebook <> Twitter
Slyfox Exteriors Co.
Slyfox is offline   Reply With Quote
Pre Fabricated Truss for Patio roof seth Building & Construction 6 07-18-2009 08:23 PM
Protruding nails through exterior patio roof miami789 Roofing/Siding 7 06-25-2007 03:42 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 07:17 AM
