Patio Roof Issue: Water Or Paint Wearing Off? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-20-2009, 05:17 PM   #1
Patio Roof Issue: Water or Paint Wearing Off?
Can someone look at these pictures and tell me if it's actually a water issue or if it's just the paint wearing off?
http://www.flickr.com/photos/8922855@N07/4029681943/
http://www.flickr.com/photos/8922855@N07/4030436748/
http://www.flickr.com/photos/8922855@N07/4029681729/
http://www.flickr.com/photos/8922855@N07/4029681621/
kirridam is offline   Reply With Quote
Old 10-20-2009, 06:13 PM   #2
Sure looks like a moisture issue of some sort.
Josh Jaros Remodeling in The Woodlands, Texas www.jarosbros.com
jaros bros. is offline   Reply With Quote
Old 10-21-2009, 04:05 AM   #3
Historic Restorer
Filbee's Avatar
That is moisture. What kind of roof is it?
Filbee is offline   Reply With Quote
Old 10-21-2009, 06:20 AM   #4
It's the roof of my front patio/porch. What do you think I should do to solve it? I'm attaching a picture of the problem area. Any advise would be very helpful.
thanks,
kirridam
Patio Roof Issue: Water or Paint Wearing Off?-patiomoistureissue.jpg
Old 10-21-2009, 06:27 AM   #5
747
registered
747's Avatar
Rewards Points: 534
Its hard to say. Do you have aluminum soffits. Where you could easily take them down and see what is going on under there? Also it looks like a new home. Get the GC out there who built it. It could be a small whole or no ice and water shield. Its hard to say.
747 is offline   Reply With Quote
Old 10-21-2009, 05:10 PM   #6
Here's a close up picture: http://www.flickr.com/photos/8922855@N07/4033310278/
Yes, I'm going to contact the warranty company. But if they do turned me down, what I can do easily to fix it?
Old 10-22-2009, 05:31 AM   #7
Historic Restorer
Filbee's Avatar
Check the roof for improperly placed nails (using a flatbar, lift shingles individually and check under them; then use roof cement in caulk tubes to seal the shingles back down). It is common for some yahoo with a nailgun to just shoot them anywhere on a shingle, resulting in nails being placed to close or right underneath butt joints in the shingle roofing. Also, do the gutters overflow? They may be clogged. Do you have drip edge along the edge of the roof? Are the starter shingles staggered with the first row of dimensional shingles? Are the counter flashings and apron flashings installed into the brickwork (in a reglet)? Are they caulked sufficiently? Does the second story window have any cuts or expansion holes in the brick sill exposed?
Need opinion on this roof profenx Roofing/Siding 14 10-12-2010 12:56 AM
Painting a room for new baby. Lots of questions. SuperAkuma Painting 15 01-01-2009 10:18 AM
oil base paints NoExperience Painting 30 09-04-2008 05:37 AM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
