Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 07-13-2011, 02:46 PM   #1
Patio Cover Roof Underside
Hi All,
I just got my permit for a detached patio cover in Miami, FL. My plans call for T-111 as the base sheet for my roof with the grooves exposed and 5/8 CDX plywood sheets on top of that. My goal with the T-111 is to mimic the look of T&G that I have in the house.
Is there any alternative to the plan that is cheaper than T&G? I'm worried about the T-111 warping over time.
Thanks.
Jeoroc24 is offline   Reply With Quote
Old 07-13-2011, 02:53 PM   #2
Vinyl soffitt material that is ventilated. Not wood-like, but likely cheaper and easier to install and maintain.
bob22 is offline   Reply With Quote
Old 07-13-2011, 03:05 PM   #3
Super Moderator
This would not be cheaper, but since the size is not too dramatic, it should not break the bank either. I would prefer the look and dimensional stability of Car-siding lumber, which is tongue and groove for a no seam appearance and can also be cosmetically stained for a more aesthetic appearance.
Ed
Stay Tuned For Our New Informative And Helpful Web Site, Coming Soon
Ed the Roofer is offline   Reply With Quote
Old 07-18-2011, 08:18 AM   #4
Ed,
I've decided to go the t&g route since the price difference is not significant. What's the best way to attach the t&g boards to the top of the rafters? They will be sandwiched between the rafters and the plywood sheathing. The rafters are 2x6 and spaced 22.5" o.c.
Old 07-18-2011, 01:42 PM   #5
Pro Slate Roofer
tinner666's Avatar
Oops!!!!!!!!!!!! Wrong advice given for lack of attention!
Frank
tinner666 is offline   Reply With Quote
Old 07-18-2011, 06:45 PM   #6
Super Moderator
Originally Posted by Jeoroc24 View Post
Ed,
You "Toe-Nail" the Tongue portion of the siding, which gets installed perpendicular to the direction of the rafters. I think about 12" On Center with a framing or trim nailer should be sufficient, but it is best to check with the manufacturers recommendations and also for sizing and spacing of the fasteners.
You will be very pleased with the final appearance.
Ed
Old 07-18-2011, 07:04 PM   #7
Pro Slate Roofer
tinner666's Avatar
Thanks Ed. I misunderstood his selection and thought he was still using T-111 for some reason.
Nail pattern won't matter since it's under the plywood. It can be face nailed since the nails will be covered by the plywood, of nailed in the tongue.
TIP: Take regular measurements for the side you are working towards! Jocky the T&G as needed to stay straight. Failure to do so can leave you with a full board at one end, or even the middle, and only a piece of board, or even needing a filler strip elsewhere!
Frank
Old 07-18-2011, 07:11 PM   #8
Pro Slate Roofer
tinner666's Avatar
BTW, you never mentioned what particular T&G you're using, nor the dimensions. Beaded 3-1/4"? 6"? 8"?
2 nails for 3-1/4" to 6" if face nailing, more if wider, but don't nail the outer edges until the next piece is aligned. Making it too tight can make you cause damage when driving each piece into place.
Frank
Old 07-19-2011, 03:27 AM   #9
Super Moderator
It's called Car Siding.
I remodeled my apartment ceiling with it, purchased from Menards, then stained it with a Gun-stock finish.
http://www.menards.com/main/paint/pa...282-c-8185.htm
Ed
Old 07-19-2011, 09:19 AM   #10
I will likely be using 1x6 T&G pine or cypress boards unless I can find the car-siding material Ed was referring to at my local lumber yard. Toe-nailing doesn't make sense to me in this application since the plywood is going directly on top of the T&G boards. I think face nailing will work.
I was wondering what size nail I should use.The plans call for 8d nails for the plywood. Would this work for the T&G boards as well?
Thanks.
Old 07-27-2011, 10:48 PM   #11
Bump. No answer?
Roof leak nightmare..... it won't stop amandat37 Roofing 52 04-22-2011 01:47 PM
Patio Roof Beam Span slakfu Building & Construction 4 06-03-2009 11:45 PM
How to hang screws from soffitt - the underside of the outer edge of the roof Synthia212 General Discussion 5 03-10-2009 06:08 PM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing 9 02-05-2009 08:33 PM
Patio Cover - Need help/suggestions DIYer Building & Construction 7 02-19-2006 10:00 PM
