Patching A Flat Roof With Existing Coating - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 12-14-2012, 06:04 PM   #16
Rewards Points: 18
Thanks Jagans. Yes.. earlier my roof was not leaking but today there was a small leak in the vicinity of the areas where I had earlier applied Henry's 208r wet patch seal.
I tried couple of local roofing contractors but all of them are fully booked. Any suggestions for something I should till I get a licensed contractor to take a look?
Thanks,
Arun
anupkat is offline   Reply With Quote
Old 12-23-2012, 05:33 PM   #17
some tar or a product called silver seal should work until you get it properly fixed. this is no permanent fix just a patch that will fail in time you dont want to continue to let the water in as that will cause more problems beyond belief.. water damage .. hope that helps matt
seaocean_180 is offline   Reply With Quote
Flintlastic SA over existing torch down roof? aribert Roofing/Siding 2 05-16-2012 08:32 AM
will a flat roof always leak............. cappuccino Roofing/Siding 6 04-19-2011 05:16 PM
Best way to replace/insulate a flat tar-gravel roof Hexar Roofing/Siding 19 10-08-2010 01:17 AM
Flat roof repair/replacement questions zmt Roofing/Siding 4 02-23-2010 12:24 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 05:08 PM
