Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 05-07-2008, 10:00 AM   #1
pjm
Patch a hole in my roof
Well I just had my plumbing inspection on my kitchen and it turns out my sink vent pipe needs to be moved as it's to close to my upstairs window. I will be having the plumber move it this week and he said he will cap the pipe so it won't leak until I repair the hole. Can anyone let me know what steps I need to take to repair where the old hole is? My kitchen is open in the ceiling right now so I can see where the rafters run. I just don't know the first thing about repairing roofs so any help would be great. Also if you think it might be above me, what should I expect to pay to get this repaired?
Thanks.
pjm is offline   Reply With Quote
Old 05-07-2008, 10:12 AM   #2
Depending how big the hole,you could probably screw a piece of metal over it.Heres a link that might help http://www.repair-home.com/Replacing_Asphalt_Shingles Hope that helps
johnk is offline   Reply With Quote
Old 05-07-2008, 10:46 AM   #3
pjm
It's only a round hole for 1 1/2" pvc pipe to fit through. Maybe the sheet metal would work. Thanks for the site link i'm sure it will come in handy.
Old 05-07-2008, 11:25 AM   #4
pjm
found this website very close to what I will be doing. I figured I would share it with everyone here in case anyone else had a similar situation.
http://www.hammerzone.com/archives/r...ak/smhole.html
Flat roof questions, advice, ballpark estimate JerryH Roofing 18 11-07-2008 05:08 PM
Reasonable Roof Patch Job? Contessa777 Roofing 11 02-16-2008 09:23 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing 4 11-19-2006 07:17 AM
