Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 01-19-2011, 03:56 PM   #1
The Big Builder
Patch hole in gutter while it is still cold and wet
OK. So I did something pretty stupid. The gutters were completely blocked up with ice and I needed to get it out. While I was chipping it out, I put a hole in the bottom of the gutter. Now the water drips in that spot.
You can all laugh now.
I know htere is the gutter sealant but you need it to be dry and within a certain temperature.
What if I don't want to wait and do a temporary patch. Is there somethign I can use? Will plumbers puddy do anything? Are there any options? I live in the northeast and it is snowing and cold. Won't get to replace the gutter until the summer.
Any tips welcome.
bigbavarian is offline   Reply With Quote
Old 01-19-2011, 03:57 PM   #2
Yikes. Not too much you can do right now until it warms up.
It is much too cold for anything to effectively seal.
BamBamm5144 is offline   Reply With Quote
Old 01-19-2011, 04:19 PM   #3
It would seem that a couple of flat or fender washers, depending on the size of the hole, a bolt and nut, and a dap of whatever caulk you have handy should at least slow it down until spring.
Old 01-19-2011, 04:45 PM   #4
You can use a two part epoxy like cold cure epoxy resin or aqua set epoxy resin both found here:
http://www.fibertek.ca/epoxy.htm
or the hardman double/bubble silver two part epoxy adhesive found here: http://www.glueonline.co.uk/shop/Two_Part_Epoxy_Adhesives.html
epson is offline   Reply With Quote
Old 01-19-2011, 04:53 PM   #5
The Big Builder
thank you for the information. The cold resin looks like a good solution.
Old 01-19-2011, 04:55 PM   #6
Anytime…
