-   -   Patch hole in gutter while it is still cold and wet (http://www.diychatroom.com/f9/patch-hole-gutter-while-still-cold-wet-92838/)
bigbavarian 01-19-2011 02:56 PM
OK. So I did something pretty stupid. The gutters were completely blocked up with ice and I needed to get it out. While I was chipping it out, I put a hole in the bottom of the gutter. Now the water drips in that spot.
You can all laugh now.
I know htere is the gutter sealant but you need it to be dry and within a certain temperature.
What if I don't want to wait and do a temporary patch. Is there somethign I can use? Will plumbers puddy do anything? Are there any options? I live in the northeast and it is snowing and cold. Won't get to replace the gutter until the summer.
Any tips welcome.
BamBamm5144 01-19-2011 02:57 PM
Yikes. Not too much you can do right now until it warms up.
It is much too cold for anything to effectively seal.
DexterII 01-19-2011 03:19 PM
It would seem that a couple of flat or fender washers, depending on the size of the hole, a bolt and nut, and a dap of whatever caulk you have handy should at least slow it down until spring.
epson 01-19-2011 03:45 PM
You can use a two part epoxy like cold cure epoxy resin or aqua set epoxy resin both found here:
http://www.fibertek.ca/epoxy.htm
or the hardman double/bubble silver two part epoxy adhesive found here: http://www.glueonline.co.uk/shop/Two_Part_Epoxy_Adhesives.html
bigbavarian 01-19-2011 03:53 PM
thank you for the information. The cold resin looks like a good solution.
epson 01-19-2011 03:55 PM
Anytime… :thumbsup:
