OSB Vs Plywood - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 02-18-2012, 12:19 PM   #1
OSB vs plywood
is osb still an unsafe product to use as roof decking.
have a new project and a renovation. metal roofing to cover.
ty.
zeekdafreek is offline   Reply With Quote
Old 02-18-2012, 12:23 PM   #2
Rewards Points: 13,732
What type metal roofing are you using?
Old 02-18-2012, 12:59 PM   #3
Rewards Points: 626
You can use OSB But I love plywood.
Nailbags is offline   Reply With Quote
Old 02-18-2012, 02:02 PM   #4
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
ty.
OSB was never an un-safe product, was it?
Oh. You were laughing about that. Must be some inside joke or something.
titanoman is offline   Reply With Quote
Old 02-18-2012, 02:09 PM   #5
With some metal roofing you do use a soild sheathing under it that's why I asked.
Old 02-18-2012, 02:28 PM   #6
Disabled wood vet
titanoman's Avatar
Yeah, I've put solid sheeting under metal. And concrete and clay tile, which was weird, I thought.
Old 02-18-2012, 02:32 PM   #7
Looks like it may be just another of the one hit wonders.
Old 02-18-2012, 02:55 PM   #8
using osb when putting down metal is a no no the screws wont hold over time and will back out are become weak over time due to the fact there is no holding power with osb.
if you are going to use a standing seem and need a solid deck then i would use no less than 1/2 plywood.
if you are going to use a ribbed metal then plywood are strapping
r00ferguy is offline   Reply With Quote
The Following User Says Thank You to r00ferguy For This Useful Post:
mae-ling (02-18-2012)
Old 02-23-2012, 07:02 AM   #9
thanks. that makes a lot of sense.
zeek
Old 02-23-2012, 07:04 AM   #10
and i appreciate it.
Old 02-23-2012, 07:23 AM   #11
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Real wood planks make a better deck. It's on record as lasting 100's of years. Gaps don't affect it either.
tinner666 is offline   Reply With Quote
Old 02-23-2012, 08:42 AM   #12
Roofing Contractor
That's a fact!!!
In regards to gaps however up here in MN we have to deck over planked board with gaps greater than 1/2in. The city requires a solid nailable surface as does the shingle manufacturer. In the past we've gone over roofs without redecking with 1/4in gaps and every now and then you'll end up with a whole row you have to nail high in order to bite into wood.
I feel the best deck material out there is tounge and groove.
We did a tear off last Fall with T&G were the installers didn't push them together. We ended up having to do a deck overlay since the seams were not strong enough to support nails.
dougger222 is offline   Reply With Quote
Roofing plywood advice needed jimd206 Roofing/Siding 2 04-24-2011 11:58 PM
Can I tile over old plywood with no gaps? JFERTICH Flooring 5 02-21-2011 02:52 PM
Can I use Thin Set Mortar over Interior Grade Plywood? JFERTICH Flooring 1 02-19-2011 05:08 PM
Fixing a screwup - stain on oak plywood brich Carpentry 9 05-13-2010 11:09 PM
Hardwood Subfloor: OSB vs. Plywood vs. OSB + Plywood italoblu Flooring 2 07-31-2008 12:11 PM
