Original Fascia Boards Need To Be Replaced - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-24-2010, 05:05 PM   #1
100 year old Fascia replacement, please help
I have a stand alone shot gun style 100 year old, brick row house. Roof has fascia, (NO SOFFIT) on 3 sides, Flat roof angled slightly toward rear( east) of house, where main and only rain gutter exists.
Objective: Original, circa 1910, Fascia boards need to be replaced. ( No kidding.)
Elastomeric Roof coating to be applied following this process. New Rain Gutter and 2nd floor porch ceiling, also.
Question:
Simplest way to remove metal from boards, remove boards from brick doing least harm to brick and how to apply new ( metal) fascia boards? Can I lay on roof and do this? I have to repair brick under a section of it and hope it can be done without erecting a scaffold. I am one person, have one other to help.
Should I cut metal roof at top of board, considering I will be applying new metal boards, sealing edge with WHAT product, technique, etc.
Who out there has done this.
Also, BEST Elastomeric product for roof ( and wall project for next spring) and why do you like it? Prefer one step, no primer if one exists. I will use primer if best option but I saw one UTUBE with no primer.
Also, would love to put roof top cistern up there. Any info on that. Joists are 10 x 4's. or so. I have big garden in back and this could water it all summer and fall.
Thank you.
Last edited by brickhaus; 08-24-2010 at 05:27 PM. Reason: my first submission did not go through so i had to test it and now i am editing the test
brickhaus is offline   Reply With Quote
Old 08-24-2010, 10:47 PM   #2
Rewards Points: 956
pictures would help
federer is offline   Reply With Quote
The Following User Says Thank You to federer For This Useful Post:
seeyou (08-25-2010)
Old 08-25-2010, 09:07 AM   #3
photos upcoming must climb ladder
thanks. i have to climb the ladder and take and then post. thank you for your reply and i will get back to you asap.
Old 08-25-2010, 10:10 AM   #4
Rewards Points: 79
Until pictures arrive - I can say that the integrity of the mortar (which if original is probably questionable) and that they are the top courses of brick will require some careful removal on that facia. Scaffolding - even ladders with plank and ladderjacks - would be wise. I would cut as much of the facia away with a small - easy to handle power saw using a blade you don't care about as you'll hit brick sooner or later. Then deal with the small pieces of fascia, hopefully a few inches each, that remain by splitting them away, again not striking the wood. A pair of wire cutters or similar tool might do it. Then all you have left are the cut nails which will NIP off. Main thing is to get it off without jarring the brickwork unless you intend to point and or relay some bricks.
jackofmany is offline   Reply With Quote
Where do I nail Aluminum Fascia? irlizard Roofing/Siding 10 09-07-2016 12:21 PM
Fascia Board what to do? superstick Roofing/Siding 6 10-18-2008 07:19 PM
Cutting my 2 x 8 fascia boards joefromcal Roofing/Siding 4 09-09-2008 09:08 AM
replacing fascia board joefromcal Roofing/Siding 12 08-18-2008 06:33 PM
Fascia cover filled with water/ice causing leaks brianbh Roofing/Siding 10 02-11-2008 07:34 PM
